OEM 19" tires $370 each??
the treadwear rating on the 19' potenza RE050a's is 140...140 is lower than any other tire brand that can compare to them...Go with another company because you will need to replace your tires every 11-13k miles and they are 260 front 280 rear from tirerack..Nitto NT555's are good tires that are competitively priced..check them out
My experiences with Falken are great. Only thing I've ever noticed is an increased road noise at-speed versus the more expensive brands.
For the record, my experiences with Falken are mostly with the ZIEX ZE-502's (tread similar to the FK-451).
Originally Posted by HansMoleman
if you are just looking for some cheap tires discount tire direct has a set of these for $189 each:
Falken GR Beta FK-451
Exotic looks, style and performance.
245/40ZR-19 94Y B
UTQG: 280AA
Meets or exceeds original equipment speed rating
245/40ZR-19 94Y B
UTQG: 280AA
I'm in the market for a 245/40-19 tire myself.
January Issue Car and Driver .....
.....tested 12 High Performance tires.
Goodyear Eagle F1 GS-D3's came in first overall.
In addition to accumulating the most points they got exceptionally high praise for traction and forgivness inthe wet.
They were not the most expensive and it was noted their treadwear was a very good 280.
Also, the Bridgestones most of us have were like 10th on the list.
Do they make the Goodyears in our size ...... ?Beat's me. If anyone checks I'd like to know. My 06 Coupe is far from needing rubber but I'd definitely give the Goodyears a shot based on the article.
BTW, they have a wicked tread pattern,too!
Anyone wanting to read the article PM me and I'll dig it out .
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
anyone know where to find toyo T1S's....i kno they discontinued them, but i met some dude with an X5 and he had them on i was like where did u get those tires and he told me to look on line! so if anyone know where to find them lemme kno... how do u guys think they would compare to the Goodyear f1's
FS[Canada]: 16" Ronal Rims with 205 65R16 Michelin X-Ice
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
