What does that mean!?
Old Feb 12, 2006 | 04:18 AM
GTT's Avatar
GTT
G35 Twin Turbo
Ok.. I pushed the VDC button for 20 sec, and then it just disappears and didn't come back. I turned my car off then started it again everything fine
I asked my brother he said maybe it turn off the Traction %100 and the APS
Old Feb 12, 2006 | 04:30 AM
trackmagic's Avatar
Originally Posted by GTT
Ok.. I pushed the VDC button for 20 sec, and then it just disappears and didn't come back. I turned my card off the started again every thing fine
You didnt know? It gives you about 75 more hp on average. Its power mode.
Old Feb 12, 2006 | 04:50 AM
GTT's Avatar
GTT
G35 Twin Turbo
Funny
Old Feb 12, 2006 | 06:00 AM
Dan_K's Avatar
VDC is only off when the "VDC Off" light it on.
Old Feb 12, 2006 | 06:07 AM
mrjonang's Avatar
great find
Old Feb 12, 2006 | 04:48 PM
GTT's Avatar
GTT
G35 Twin Turbo
Try what i did, then u will know what i mean
Old Feb 12, 2006 | 04:50 PM
truplay8's Avatar
THE BATMOBILE
+1........
Old Feb 12, 2006 | 04:54 PM
cungkpham's Avatar
i did that before, but mine was different... when i had my stock 18's, i turned off my VDC and did doughnuts, the SLIP light went on but there was no traction control. after my doughnuts my SLIP light was still on... WTF, so i turned off the car and restart... and the light went was gone... 15 seconds later, my Power Steering pump went out warranty covered it
Old Feb 12, 2006 | 05:15 PM
Msedanman's Avatar
O.F. Administrator
That's correct. In this scenerio, with the VDC light off, the VDC is on as it normally is, and stays on until the ignition is turned off and the engine is restarted.
What GTT has discovered is the way to prevent the VDC from being turned off. Apparantly the techs at the shop have need of this feature for something.
C.
Old Feb 12, 2006 | 05:33 PM
GTT's Avatar
GTT
G35 Twin Turbo
If u turned the VDC off, you car won't turn it off actually. It will make the VDC less sensitivity. So if your car slipped really hard with VDC off the traction will control your car (I tried this on snow, I tuned the VDC off and every time my car slips I can hear the traction working).
SO, my guess when you do push the VDC for 20sec, the VDC will turn off completely.
