Cheaper 05 6MT Coupe tires
Mar 13, 2006 | 04:20 PM
But the 19's have 8.5 inch rear rims which are perfect for 265s.
The 2003s and 04s have 8 inch rims all the way around.
Agreed that tire pressure sensors are a real PITA! The dealer wanted 190$ to put mine back on and calibrate them. Forget it. I've done without them for this long and will be fine until the next time I get new tires, at which time I will put them back on when the wheels are accessible. I can deal with the light on the dash.
The manual says that even when you change tires or replace a damaged tire that they should be reset by the delaer. I went to a couple of tire places and no one could reset them.
Reply 0
Mar 13, 2006 | 07:38 PM
There is a member on here that is running 245/35/19 and 275/35/19 PS2's on the stock 19" wheels. He has driven 7500 or so on this setup and has not had any problems and said the car drives great. I forget his exact name, hopefully he will chime in.
Reply 0
Mar 13, 2006 | 10:28 PM
Quote: But the 19's have 8.5 inch rear rims which are perfect for 265s.
From the specs on the Infiniti website:
"Wheels and Tires
Split 5-spoke, 8.0 x 19-inch alloy.
225/40 R19 (front) / 245/40 R19 (rear) Y-rated summer performance"
http://www.infiniti.ca/en/models/g35...delCode=G2VG56
Reply 0
Mar 13, 2006 | 10:52 PM
Quote: There is a member on here that is running 245/35/19 and 275/35/19 PS2's on the stock 19" wheels. He has driven 7500 or so on this setup and has not had any problems and said the car drives great. I forget his exact name, hopefully he will chime in.
Up to each to choose. I overtired a wheel once about 15 years ago. Biggest waste of money- car was wallowy and imprecise. I may as well have been running 135 wide econo-tires.
"has not had any problems and said the car drives great".
For my money, I'll pick the tire mfg and a company like tirerack, over "a member's" seat of the pants. In the case of the PS2s, the company is responsible for more than half the Formula 1 teams and the space shuttle. I think their engineering and test data is probably better, just a hunch.
From a liability perspective, it's a safe bet that all bets are off if you run tires 30mm wider than the mfg spec for a wheel width. I had one company (Costco) refuse to mount tires that were a single width beyond recommended for my stock truck wheels. There's gotta be a reason for that?
Cheers,
Derek
Reply 0
Apr 7, 2006 | 12:43 AM
Derek,
I just measured my 19"s and the rear wheels are 8.5". So the website you referred must have bad data. Here's the correct info. for the 05 6MT Coupe
19” Aluminum-alloy, 5-spoke, polished, FR 8JJ/RR 8.5JJ
Also, it was TireRack.com that recommended the FR 245/35 RR 275/35 combination.
Reply 0
Apr 8, 2006 | 12:08 AM
Bites,
You are right, and I am wrong. The info I posted was cut and paste direct from the Infiniti.ca website (also found in the brochure). Who cares that it's 1 am here- I went out and measured my rims in the garage after reading your post. You've made my day . I've wanted to move to a different setup for my next tire order, but felt I was stuck, given the prohibitive burden of buying wheels and tires, not just tires. Now it's off to the Michelin site to see what is possible. Thank you.
Cheers,
Derek
Reply 0
