Xenons Again...
Old 09-01-2003, 08:40 PM
FDNameBrands's Avatar
Re: Xenons Again...
..NOT THE STINKING HEADLIGHTS... WASTE OF TIME AND MONEY.. AND YOU PROBABLY STILL WONT SEE A DIFFERENCE.
<hr></blockquote>
Projector HID’s would be a big improvement over the G's reflector HID. Ever had an S2000, SC430, SL500… pull right next to you at a stoplight, it almost drowns out the G’s HID headlights. Besides it's his car let him do what he wants.
  #36
Old 09-02-2003, 05:30 PM
TooFast4U's Avatar
Re: Xenons Again...
Here is what I did on my coupe:
1. Adjusted the headlights a bit higher - helps a lot.
2. Changed the fog/hi bulbs to OSRAM Silverstar. Stock wattage, but brightest aftermarket bulb you can get. Don't be fooled with 6000K versus 7000K or 8000K - check it out for yourself. The higher the K - the less reflected light your eyes will actually see. Our stock 4500K (approx) bulbs will give you the most light on the road and the reason I liked the OSRAM fog's is they replicate a similar color.
3. Went with the CATZ ZETA on the fog/hi bulbs - it really helped brighten them a lot.
I am very satisfied now - the light dispersal still isn't as good as good projectors - but I won't spend the hundreds or thousands it would cost for new lights. Plus, this gives me a very bright, very clean, white light pattern. And all told - it cost me $45 for the bulbs, $120 for the Zeta and a few hours of time. I drove next to a Z the other night and my lights were definitely brighter and did a better job of illumination than his. Figure that is as good as it gets w/o going a lot more expensive.
jeffbdye
06-01-2018 03:51 PM
twentyeggs
09-11-2015 03:58 PM
VANST3R
Lights
07-27-2015 08:20 PM
madler
Lighting
32
03-16-2003 11:52 AM
Quick Reply: Xenons Again...
