Subwoofer
Old Apr 14, 2006 | 06:14 PM
skyline04's Avatar
Subwoofer
Do i need to change my stock head unit to put in a woofer and amp?
Old Apr 14, 2006 | 06:16 PM
Heikes's Avatar
Not if you get an amp with high level inputs or a high to low-level converter. I would suggest the amps with it built in.
Old Apr 14, 2006 | 09:18 PM
truplay8's Avatar
THE BATMOBILE
nope
Old Apr 14, 2006 | 11:17 PM
kid1767's Avatar
Nope
Old Apr 16, 2006 | 10:30 PM
spadak's Avatar
Check out the JL Audio line of amps, they have really good sub amps with line-in inputs built in, that's what I'm using with a 10" JL W6V2, sounds great!!!
Old Apr 17, 2006 | 12:09 AM
ISMSOLUTIONS's Avatar
The ultimate mix for keeping your factory head unit and bypassing the factory amp is to use the JL CleanSweep.
I did that with my Bose system - removed the Bose amp - went with JL amps, 2 10W6's, and replaced all the inside speakers...love it to the moon!
For info - call Rommel at Street Sound Plus in Van Nuys - tell him Rick sent you!
Rick
Old Apr 19, 2006 | 03:43 PM
Beverlykid's Avatar
not if you want to way down your car
Old Apr 19, 2006 | 04:36 PM
JEVERYDAY's Avatar
dONT THINK SO. I GOT A BASSLINK AND WORKS FINE
Old Apr 19, 2006 | 06:33 PM
WYSIWYG's Avatar
For those who have the JL setup... whats the going rate on the setups you guys have.
Old Apr 19, 2006 | 07:00 PM
Gman2004's Avatar
You don't really need to change anything out. Just add an amp and sub woofer and you're good. Use the factory speakers for the highs and mids. Just turn the gain up on the amp for the bass that way you can have the bass turned down on the radio which will allow you to use the factory speakers as I suggested above. Not show quality, but sounds good.
I am using a soundstream 600 and 1 12" audiobahn alumn.
Old Apr 22, 2006 | 05:43 PM
teog35's Avatar
jl audio is tight, hardest hitting speaker i've ever heard
im currently runny a pair or jl 10 w3v2 with 500/1, going to up grade with jl13w6v2 with 500/1, i wonder how this is going to sound, Is this 500/1 amp strong enough to push a 13in w6v2? should i upgrade to 1000/1? any advice?
Picture Share
Feb 4, 2018 12:41 PM
Hotdawwgman
Sep 18, 2015 04:19 PM
JustinMKN1
Sep 18, 2015 03:40 PM
Frostbite91
Aug 2, 2015 04:59 PM
