Quote:
MREV+ on an 05 Auto???Originally Posted by Klumzyee
stock dynos? mrev has been dynoed back and fourth countless of times by myself and motordyne as well as other members
nope mRev is ONLY on 05-06 6MTs
Quote:
That's were your wrong dude and the reason for my posts!Originally Posted by Klumzyee
I have an 05 AT - got with Tony and put the MREV+ on my car and Dyno'd some nice gains with the 1/2" spacer - you should call him and catch up
Rick
so the Mrev works with auto??? Does it work with only the 1/2 spacers? How much extra gain with it on?
Quote:
Remember - the AT's already have the lower plenum - but MD mods to them do make a difference as well.Originally Posted by Mr_pharmD
In my opinion - Tony did it again and squeezed out even more power on our machines!
Rick
Quote:
I don't show my dyno's for specific reasons - I have spoken with Tony and I did get 12.2 HP increase - my car is heavily modded - so it is feasible that I would get more than the average increase - just how much, we're not sure.Originally Posted by Mr_pharmD
do u have dyno results of before and after?
So Tony now has some more experimenting and tests to do...
Rick
I might be interested. So what parts would I need to get? Do I just need the MREV plus if I have the 5/16 iso thermal spacers? I thought the mrev plus was only for the 298hp engine and will not work with the earlier models.
http://www.conceptzperformance.com/C...71.128.253.210
I must refer you to Tony...sorry...best you deal with The Man directly...Originally Posted by Mr_pharmD
I might be interested. So what parts would I need to get? Do I just need the MREV plus if I have the 5/16 iso thermal spacers? I thought the mrev plus was only for the 298hp engine and will not work with the earlier models.http://www.conceptzperformance.com/C...71.128.253.210
Tony - you readin' this???
Rick
i dont think him spending the few extra $100 bucks will be worth the small difference between the 1/2" spacer vs machined version of his stock manifold with a 1/2" spacer.. unless theres a deal going on where you can swap your stock lower collector for a machined one for less $
post dyno results when you can cause wouldnt mrev+ with 1/2" spacer cause more low end loss for like a 2-5hp gain (compaired to just a 1/2") on the top end?
Honestly it depends on what your trying to accomplish in your car. For me - the ultimate NA car - so every bit helps everywhere. I have loads of bottom end and gears - so if I were to get a little loss - which I didn't get, it wouldn't bother me.Originally Posted by Klumzyee
i dont think him spending the few extra $100 bucks will be worth the small difference between the 1/2" spacer vs machined version of his stock manifold with a 1/2" spacer.. unless theres a deal going on where you can swap your stock lower collector for a machined one for less $post dyno results when you can cause wouldnt mrev+ with 1/2" spacer cause more low end loss for like a 2-5hp gain (compaired to just a 1/2") on the top end?
Again - my car is hugely built and not something to base other cars gains on - so it can't be used as a base.
I don't disagree that that 2HP is worth $200 - if that is the result - for me it was more - but when $200 intakes give you 5-7 why not $200 for the same in a manifold mod - it all does add up in dollars and HP over time.
Rick
so is it worth it 05 auto 5/16 mrev plus
200.00 + ....plus install
Hi Guys,
Yes, its true... I finally got around to testing the MREV+ on a non-revup engine and it made great gains. In fact, the lower plenum modification made even more average power than a 5/16" spacer.
All the dyno results are posted here:
https://g35driver.com/forums/intake-exhaust/92810-mrev-installed-non-revup-engine.html
I've expanded upon how the lower plenum was machined. And recently, I expanded upon the machining process even more.
The lower plenum modification makes very good gains. And it made quite a bit more TQ than the spacer ever made.
The best part is you can combine the the lower plenum modification with a spacer for even more gains.
Tony
PS: Everything is shown in the link above.
Tony
how much gains on 05 g35 coupe
using 5/16 mrev plus
