cel for gas cap?
Old Apr 17, 2006 | 02:52 PM
draxxus07's Avatar
cel for gas cap?
i was throwing a cel so i went to go check it out, the stealership said im throwing a code for my gas cap... cant remember the actual # of the code but i heard its common if you have aftermarket gas caps but mines oem never changed
just curious if anyone else has had this issue before?
Old Apr 17, 2006 | 03:59 PM
truplay8's Avatar
THE BATMOBILE
never heard of that..........thats weird.........there either completly making **** up, or this really exists
Old Apr 17, 2006 | 04:11 PM
Curt G's Avatar
Very common. Just make sure your cap's on straight and tight. Any loss of pressure in the gas tank will throw a code.
Curt
Old Apr 17, 2006 | 10:15 PM
ark_nc's Avatar
That's normal. It's part of the emissions system (I think under ODB II), so it'll throw a CEL if "disabled" i.e. left loose.
Old Apr 18, 2006 | 01:22 AM
hai109's Avatar
Very common for OBDII. Loose cap is common. If you keep throwing the code then there's a leak in the EVAP. system of your fuel tank. If just installed a stereo then hopefully you didn't tap a screw into the gas tank. Very expensive mistake and will not be covered under warranty. Make sure you cap is tight when you refill. After they reset the code it will take 2 full cycles for the CEL to come back on again if the system detects a leak. Hopefully it's just the gas cap. But the EVAP system for OBDII is a pain sometime to isloate and fix because it takes 2 full cycles to get the light to come on.
Old Apr 18, 2006 | 03:48 PM
draxxus07's Avatar
my car is all stock... its only got 10k miles on it, I took it to a Nissan dealership i figured Infiniti would act stupid about it and thats what they told me it was
Old Apr 19, 2006 | 12:16 AM
hai109's Avatar
Just keep an eye out on the code that it's setting. If it comes on again then tell the service writer it's the same code and i made sure the gas cap was tight. Tell them to try again with that excuse...=o)
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
Jay123
Sep 28, 2015 08:42 PM
Hogbone
Sep 28, 2015 06:44 PM
vamarris
Sep 26, 2015 12:56 PM
