Weird Noise Shutting Down
Old 08-25-2006 | 11:34 AM
watsgoodG's Avatar
i think it is normal i started hearing it around 1500 miles after i really beat the car up...i think it juste happens when u break the car in...
  #32
Old 08-25-2006 | 12:41 PM
zmoothg's Avatar
Yeah its normal but it is not right. I have drive other MTs and none have made this sound. Yea of course Infiniti tells us its normal. A TSB on the clutch would be a quite expensive blow.
I wonder if the rattling I hear coming from some part of my cabin is normal too. This is a great car, but could have been built more solid.
  #33
Old 08-25-2006 | 12:59 PM
rdurkin05g35's Avatar
i get the same thing so i just always hold clutch in when i turn it off
  #34
Old 08-25-2006 | 02:03 PM
fx57's Avatar
The noise is caused by the dual mass flywheel and is normal. At 200-400 rpm the DMF resonates and will cause all sorts of noise in the drivetrain. Pressing the clutch in disconnects the clutch and transmission from the flywheel so there is less drivetrain to make noise.
The point of the DMF is to lower the drivetrain's resonant frequency from something like 3000 rpm down to something like 300 rpm so that you only get noise when you shut down or start up your engine, not while you're driving.
  #35
Old 08-25-2006 | 02:49 PM
logik05se's Avatar
that sounds great in theory....but i also get the noise while driving...only in first gear from engagement to about 15-20 mph.
  #36
Old 08-25-2006 | 03:43 PM
dudeimjohn's Avatar
06 mt... same noise. is it me or does this manual have lots of little noises and rattles. the the tranny doesn't sound very solid, though it feels solid when you wot...
Dallsinghjr1
09-17-2023 12:25 PM
Marlin84
04-01-2020 01:52 PM
THMotorsports
Suspension-Vendor
257
12-18-2018 06:43 PM
dcsbh1
10-01-2015 04:15 PM
alinero718
09-27-2015 10:35 PM
Quick Reply: Weird Noise Shutting Down
