defective tire valve
Old Sep 15, 2003 | 11:42 PM
mvorion's Avatar
Just took home my G35C 6spd saturday. This morning, about 2 min after starting the car, the low tire pressure beep and light came on. It seems the right front tire valve is defective, or the tire was mounted incorrectly. As soon as I unscrew the tire valve, air starts to seep out, as the little needle is sticking out too far out from the valve itself.
Old Sep 16, 2003 | 02:47 PM
Merlin's Avatar
Staff ALUMNI
Re: defective tire valve
You just need the tool to screw the valve in tighter, sounds like whomever balanced the wheels did not do so. Any bicycle shop, auto parts or chain store will have it.
Old Sep 17, 2003 | 12:06 AM
mvorion's Avatar
Took the car in this afternoon, and had them replace the defective valve. All seemed ok on the commute back to work. On the commute home, the beep and light came on again, but tires don't seem to be under inflated. I'll have to call back tomorrow morning. Hopefully nothing serious or time consuming to fix. The car has only 600 miles on it.
Old Sep 17, 2003 | 07:57 PM
Merlin's Avatar
Staff ALUMNI
Keep us posted, might be a bad or mal-adjusted sensor.
Old Sep 22, 2003 | 01:41 PM
thane's Avatar
I had a similar issue. Everytime I checked my tire pressure (2003 model, no sensors) the valve would stay open on the front, right tire. Believe it or not, it took the dealership 3 visits to fix it.
Muski_G
Dec 1, 2023 11:11 AM
11bEMT
May 27, 2022 03:13 PM
eunosz
Aug 29, 2015 02:03 AM
yassy
Aug 9, 2015 07:31 PM
lemmy999
Jul 25, 2015 12:13 PM
