Is it just my 03 sedan?
Old Aug 21, 2007 | 09:37 AM
dunglan7's Avatar
Okay guys this has been going on for a while now with my 03 sedan. While driving normal, I would floor the gas to try and pass someone but my car doesn't accelerate anywhere. I would hear my engine rev up and my rpm would jump from 3k to about 7k but the car wouldn't go anywhere. It seems like it's lagging. By the time it does accelerate, I'm already past the car. They probably got scared from the car being so loud. Is it just my car or that's how the G's are?
Old Aug 21, 2007 | 09:41 AM
SLVR JDM's Avatar
MT or AT? If MT, then it sounds like you have a clutch slipping. Not sure what it would be if you are auto, but mine is not like that at all. Pedal floored = quick push back in the seat.
Old Aug 21, 2007 | 10:03 AM
kvangil's Avatar
+1...If MT, then your clutch is slipping. Time to replace it....
Old Aug 21, 2007 | 10:04 AM
dunglan7's Avatar
Sorry. It's a AT.
Old Aug 21, 2007 | 10:40 AM
sliderg35's Avatar
Originally Posted by dunglan7
Sorry. It's a AT.
It's time for a tranny rebuild. AT transmissions have wearing components also. I just had to do mine.
Old Aug 21, 2007 | 10:52 AM
dunglan7's Avatar
How would you do something like this? Also how much would it cost?
Old Aug 21, 2007 | 11:19 AM
WILLIE BEANS's Avatar
how much mileage do you have on your 03 sedan .??
my o3 sedan peels tires if i punch the gas ..
( i always use 93 0ctane .)
Old Aug 21, 2007 | 11:20 AM
dunglan7's Avatar
^ I have about 80k miles.
I always use 93 Octane gas also.
Old Aug 21, 2007 | 11:38 AM
stjohnson's Avatar
This is a torque converter problem. You either have low fluid (i.e. the fluid is leaking) or your torque converter is malfunctioning. Is shifting when accelerating moderately smooth and seemless? If so, the mechanics of your transmission are fine. The slip is from the TC.
The bad news is that this is a labor intensive repair. They have to pull the exhaust, then the driveshaft, then remove the transmission from the bottom to get to the torque converter for replacement. I don't know the cost but if you don't get it replaced, you are seriously running a risk of being caught on the side of the road.
Old Aug 21, 2007 | 12:00 PM
dunglan7's Avatar
^ This sounds about right. When I give it a little gas, it accelerates very smooth. Only when I punch the gas pedal it seems to lag.
Old Aug 21, 2007 | 12:23 PM
cato's Avatar
SouthernComfort Moderator
Reset the computer! You computer has learned your granny driving habits. Try a reset and see if the performance comes back. I have a 2003 and it still runs like a bat out of hell.
Old Aug 21, 2007 | 12:26 PM
dunglan7's Avatar
^ I'll try this. Could it be that I need my tranny flushed also?
Old Aug 21, 2007 | 12:40 PM
i think stillen has a part for the tranny
increases shifting better acceleration .. as well ..
www.stillen.com
Old Aug 21, 2007 | 01:40 PM
sliderg35's Avatar
You need to take it to a reputable transmission shop (or the dealer if you trust him). It would take a couple of days and about $1000 if there aren't any major problems. Mine was doing the same thing in MM mode in 3rd gear. Other gears were OK.
Old Aug 21, 2007 | 01:43 PM
ttrank's Avatar
Grocery getter
^+1
