Volk Challenge???....(PICS)
Old May 19, 2006 | 10:30 PM
megatron27's Avatar
First off, will this fit my car? I e-mailed the seller about the offset he said he will find out monday as they are at his work and out of town. BTW, It came off of '06 IS350.
Also I've seen almost every type of Volk on a sedan except for the Challenge. Do you think it would good on a DG?
Old May 19, 2006 | 10:45 PM
Endless G's Avatar
It will look hot , but IMO, it will look even hotter with a BBK!!
Old May 19, 2006 | 11:05 PM
vrsc's Avatar
Would look sweet
Old May 19, 2006 | 11:06 PM
Hyde's Avatar
cuz the sedan offset sucks...
u cant get a nice lip with these wheels
Old May 20, 2006 | 01:02 AM
heyitzalex's Avatar
most likely they will fit, i got my wheels of an 06 is350 and they will fit fine. however, make sure u get the correct hubcentric rings, the wheel bore should be 66.1.
Old May 20, 2006 | 01:50 AM
G35Lin's Avatar
Multi-Spoked Mod
i almost got those wheels.. should look sickk
Ed Lin
Old May 20, 2006 | 01:53 AM
LightsOutG35's Avatar
Wheels are SICK!
Old May 20, 2006 | 02:13 AM
MikeyMike's Avatar
Rollin On Dubz
Do itttttt
Old May 20, 2006 | 02:16 AM
megatron27's Avatar
can someone educate about hubcentric rings and wheel bore???
also thanks guys for the feedback on these wheels and yes BBK is a must to finish off these wheels.
Old May 20, 2006 | 02:28 AM
heyitzalex's Avatar
'This (hub bore) relates to the center hole in the wheel that centers the wheel on the hub of the car. Hub rings can adapt wheels with too larg of a hub bore to fit on your vehicle (when your vehicle's required hub bore is less than the wheel's hub bore). They are hard plastic or metal rings that fit between the wheel and the vehicle. This centers the wheel perfectly on the hub ensuring that there is no run out when the wheel is installed on to the vehicle.'
from subydude.com
Old May 20, 2006 | 05:06 AM
kailep's Avatar
those look awesome. I wish I have them.
yeah, like heyitzalex said, make sure the wheel hub matches the car's rotor hub. I have 17" on my wife's VW. The steering wheel shakes during highway speed. I thought the tires are not balance. Discount tires pointed out to me and it was perfect afterward.
Old May 20, 2006 | 05:21 AM
GLuXuRy's Avatar
saw an Altima with Challenges at the stillen meet... looked HOT... DO IT... here's a sedan from jtuned... hope this helps you make your decision
Old May 20, 2006 | 08:49 AM
03VIPG35's Avatar
That set up would look super hot.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
9tray turbo
Sep 29, 2015 10:22 PM
