awd times in rear wheel drive mode
Old Jun 5, 2006 | 11:04 PM
killerlexus's Avatar
anyone ever run their "x" with the AWD fuse pulled out?
with the fuse pulled ,the car is in rear wheel drive mode;would it be faster then a regular RWD sedan since it has the lower gearing?
Old Jun 5, 2006 | 11:15 PM
trey.hutcheson's Avatar
I seriously doubt the gearing would make up for the added weight. But that's an uneducated opinion.
And (x owner chime in here please), the diff is only transferring power to the fronts at up to something like 30mph, right?
Old Jun 5, 2006 | 11:18 PM
ttrank's Avatar
Grocery getter
I doubt it would be faster due to the weight but you could take it to the track and try it. I would think you woudl have a better launch anyway.
Old Jun 6, 2006 | 01:12 PM
Lip's Avatar
Lip
I think it's time for a X only forum. This topic has been covered quite a bit-Should be almost sticky. The X comes with different gearing compared to the RWD Auto G-
Gear Ratios
RWD AUTO :3.357
RWD 6-speed:3.538
X: 3.538
Thus they were able to retain some of the quickness off the line.
Under let's say 70, the X is pretty quick. Maybe quicker than the RWD Auto model. Not sure how much wheel spin you'd run into with the AWD chip pulled. If you were on a sticky strip, and got a good launch, you might be able to get a pretty quick pass.
Get it on the freeway, and my experience has suggested that a stock RWD auto will leave it for dead, especially past the century mark. Mind you that's just seat of the pants and from watching the speedo.
Now when you put a couple of people in there, the X's quickness goes away pretty quickly (pun intended), relative to the RWD model and the extra weight is really felt.
The X really needs a 6-speed auto or manual. That would cover up a lot of the negatives that the extra weight brings to the table.
Old Jun 6, 2006 | 01:59 PM
X is only like 200lbs heavier then a RWD. i was hoping the xtra gearing should make up for it. would i be able to SAFELY dyno the X on a RWD dyno? there arent any AWD dynos around my neck of the woods.
Old Jun 6, 2006 | 09:21 PM
ttrank's Avatar
Grocery getter
I doubt anyone would do that for you. It is not safe. From everything I have seen a X would make about 5% less whp than a RWD.
Old Jun 6, 2006 | 10:20 PM
Neal376's Avatar
this topic has been covered before
https://g35driver.com/forums/g35-sedan-v35-2003-06/95063-awd-switch-g35x.html
my X is going on the AWD dyno this weekend.
I am going to measure whp and 1320 times in RWD and AWD mode
will post video
Old Jun 6, 2006 | 10:45 PM
Neal376's Avatar
hmm... i think one day i will just remove the transer case alltogether just to see how it works out.
Old Jun 7, 2006 | 09:27 PM
Xman's Avatar
I'd say that's pretty accurate. Anyway soon I should have my X back from the shop with a RWD tranny, VB/TC upgrade. We'll see....
Old Jun 7, 2006 | 09:30 PM
Neal376's Avatar
do you still have your transfer case? lol
how did the transfer case hold up anyways?
the ATTESA (whatever) system should be able to accomidate high power.
Old Jun 7, 2006 | 10:26 PM
Xman's Avatar
The transfer case was fine.
Old Jun 7, 2006 | 10:43 PM
Neal376's Avatar
so was the destruction of your tranny AWD related?
Old Jun 8, 2006 | 07:33 PM
Xman's Avatar
I don't believe so. I have a feeling that the clutchpacks might have failed since I was able to get it into momentarily after the tranny cooled down a bit. Check out my350z.com for 5AT 350zs.
Hasanbaloch
Feb 29, 2024 08:45 PM
rezendvous420
May 31, 2020 01:26 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
Cskeet
Jul 21, 2015 05:48 PM
