Urgent: Headlamps no work!
On my bosses-wifes g35 sedan, was wondering where the fuses are located for the lights! I found a panel by the emergency panel but it contains nothing for the lights, looked under the hood and found one by the battery terminals inside of the plastic cover, all it has is a headlamp relay. Wheres the fuse??
04' G35 / 6MT / Tein Basic Coilovers
Volk 19" GT-7 Gunmetal
Re: Urgent: Headlamps no work!
damn... hope i didn't blow the relay.. When I turn the headlight **** it doesn't even dim the interior lights... But I do get the "beeeep" if i turn it while the keys are out.... i wonder if i messed the relay up
Narkotic, It says in my
Sedan ESM to check the BSM fuses specifically Fuse 'F', fuse '1' and fuse '6'. There's a BSM fuse in the block next to the battery.
If you're in Canada, there's a separate Daytime Running Lights fuse panel also near the battery.
Good luck.
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Good luck.
Update. The headlamps in fact DO work, i'ts the parking lights that don't. Therefore the rear lamps don't light up (stoplights work), and the front orange sidemarkers don't work. The dash lights don't dim either. Theres got to be a parking light fuse somewhere.... The fuses you mentioned sedanman all seem well.
