RacingBrake BBK Installed *PICS*
on
Originally Posted by G-Force
I was reading the RacingBrake web site and they show the vanes forward, rotating into the pads. This image is showing the driver's front wheel. I will call them directly to find out tomorrow because I will have mine in a week or two and want to install correctly.
See also the page from Stoptech, they show the vanes forward too. That said, I think Cru did the install correct per both sources.
Yeah, I have the same kit. He did the install correctly. I have a question for you though. Did you use the Hawk HPS pads? And if so, do you get any kind of "groaning" noise/vibration while stopping? I have gotten this since day one with the kit. And after calling RacingBrake, they say it is normal. Seems kinda weird though. It happens around 30 mph during the stop, but not at highway speeds or really slow speeds. Thanks.
Originally Posted by BigSash
Bro you should paint your calipers to complete the BBK look. get a Duplicolor brake caliper painting kit.
Originally Posted by skeleton_cru
*The caliper brackets are painted bright red by the manufacturer. I didn’t really care for the color so I stripped the paint myself and had them powder coated gloss black. After the install I now wish I would have had the stock calipers powder coated gloss black as well, but I still think it looks great.
on
No groaning noise or vibration, but I do have a metal rattling sound coming from both fronts when I go over bumps. This worries me so I'm going to remove the wheels and poke around.
Check the dust shields...they might be contacting the rotors due to vibration. Also check the anti-rattle clips. Make sure they were connected. The new pads only allow for the anti-rattle clips to be installed on the inside pad, not the outside.
Originally Posted by G35_TX
That's normal. My HPS pads do that on the stock rotors.
Just got in from the garage. I originally thought the rattling was coming from the dust shield but that was a tinnier sound than what we were hearing. When I jiggled the pad up and down that recreated the sound exactly. The instructions stated not to use the stock shims in the front and the Hawk pads did not come with shims so we installed the fronts without them. I'm going to email RacingBrake and see if we/they didn't miss something.
UPDATE: Turns out I was using the wrong termonology. Shims are attached to the back of the brake pads and clips are what center the brake pad on the caliper bracket. Doh!
So I installed the clips today and now the kit is solid. No rattling whatsoever.
![Embarrassment](https://g35driver.com/forums/images/smilies/redface.gif)
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
