What tire pressures do you run?
I run 30, though on my last road trip I bumped it up to 32 since the tire monitor sensor lit up a couple times (though historically it wouldn't come on until down to 25, which is the documented level).
You definetely don't want to go over what the tire's maximum is, and I think my factory tires only goes up to 44. Filling to 45, then when it gets hot, would be well over the limit.
Man, this question is like asking what oil do you use. You will get all kinds of answers. It depends on driving style, preference for mileage or performance, type of tires on the car, etc. There is no correct single answer.
Originally Posted by chobble19
i have a set of the forged coupe wheels on my sedan think i should run coupe psi specs?
Jeff
Originally Posted by Jeff's Classics
... My guess is that the coupe is lighter and maybe has a little more bias to the rear than the sedan. ...
Jeff
Jeff
ENVautoDetailing.com
Originally Posted by w0ady
if you're going to be a jacka$$, at least learn to spell. its retarDed.
i run 32 psi all the way around. 35 just seems too stiff for me.
-GP-
stock 17" Bridgestone (yes they suck, but I'm waiting for tread to wear then replace)... I run on 30psi always all the way around. Frequent spirited driving - decent handling (considering the sh!tty performance of the tires) and good comfort/ride.
BTW, I use to run 32 and that provides very comparable to above stated.
Maybe I should bump up to 45 to wear the tread faster. (j/k of course)
RA102223
Aug 15, 2015 09:24 PM
