coupe middys and the oem z tube..
Old Jul 6, 2006 | 01:02 PM
hongmin's Avatar
also does anyone know the labor cost to get the coupe middys installed??
also it seems like all of the sedan owners get the oem z-tube and the drop in KNN filter...
I got the KNN drop in filter already and about to purchase the polished oem Z-tube...
is there anything else i should get for my air-intake project???
Old Jul 6, 2006 | 01:09 PM
absolutg's Avatar
workin...
without knowing where you live, it's hard for anyone to provide labor estimates. why don't you just call some shops?
Old Jul 6, 2006 | 01:12 PM
hongmin's Avatar
well i went to this one shop and asked and they said 100...
i thought i was getting ripped off so i wanted to ask u guys.
Old Jul 6, 2006 | 02:20 PM
LuXXXz's Avatar
i paid 50 bucks to get it installed
Old Jul 6, 2006 | 02:22 PM
RocketG35's Avatar
Why do I bother to DIY???
I only paid $40 for get the midpipe installed. The Z-Tube you can do yourself in about 15-20 minutes....not worth having anyone else do that. Here's a great DIY - no special tools required...
http://www.6mt.net/mod-g35-350z-intake.php
You could actually do the middie yourself because its only 4 bolts, but I'm not too keen on getting underneath the car when its jacked/jack stands...makes me a bit nervous.
Old Jul 6, 2006 | 03:09 PM
g35guy86's Avatar
i paid $100 for the midpipe and IP ypipe installed.
g35guy86's Avatar
ztube i did myself in about 20 mins.
Old Jul 6, 2006 | 05:10 PM
da mayor's Avatar
the Z tube is a DIY and save the bucks for a 12 pack. the mid pipe should be 40-50 bucks good install
Old Jul 6, 2006 | 05:24 PM
G SEDAN's Avatar
i did the mid pipe myself and the hardest part was not removing the bolts but the 2 super tight rubber bushings that holds up our sedan mid pipe right now. In all honest, try a muffler shop they should be able to do it for $40 or even less. I have connections with my muffler shop and they were only going to charge $20 but I wanted it done the same day I got it so I did it 10PM at night...LOL
Old Jul 6, 2006 | 06:58 PM
Msedanman's Avatar
O.F. Administrator
That's too much.. From what I know about the install, it's a straight swap and shouldn't cost you more than about $50.
The K&N and Z-tube will finish off your intake just nicely.
C.
Old Jul 6, 2006 | 10:03 PM
vodkarocket's Avatar
Modded Member
The midpipe is seriously a 15 minute install, tops. This is one of the easiest DIY's. The difficulty level is in between clears and z-tube.
I've installed three of them now. You undo 5 bolts, drop out your stock middy, and put in the new one. Tighten the 5 bolts and you're good to go.
Old Jul 6, 2006 | 10:20 PM
hongmin's Avatar
thanks alot for the info!!!
Old Jul 6, 2006 | 10:22 PM
hongmin's Avatar
thanks alot guys for all the info!!!!
Old Jul 6, 2006 | 10:23 PM
driguez's Avatar
will 2 ramps do??
Old Jul 6, 2006 | 10:27 PM
Modded Member
Originally Posted by driguez
will 2 ramps do??
Yeah, you don't need too much clearance.
mjfenix
Aug 17, 2017 05:49 AM
mushu
Jul 15, 2015 03:55 PM
djreinx
Jul 13, 2015 05:04 PM
