Is G35s a mid-size or a compact?
I always had impression from various mag reviews that G35S is a mid-size b/c its roomy interior, but window stick says it's a compact. I love my car, but just confused.
Re: Is G35s a mid-size or a compact?
i never sit in the back, so i'd have no idea as to how comfortable or uncomfortable the back seat is... also, i had an SUV before the G, so it would be hard for me to compare.. but i've ridden in "compact" cars before.. not very comfortable.. coupes are even worse..
'03 G35 Sedan: ivory/aero body/sport/sunroof
Warning: Objects in mirror are FASTER than they appear
Considering the G35 is virtually the same length as a BMW 5'er and only 3inches shorter than a Ford Explorer, I think that you'd have to consider it at least a mid-size sedan!
Mid-sized. This is a very roomy car.
Limited Edition Twilight Blue / Premium / Graphite / Xenons
Kongz:
Shorter in length! [img]/w3timages/icons/smile.gif[/img]
About 10" shorter in height than an Explorer Sport. Otherwise, our Gs would look kinda goofy, like a big Toyota Echo or something.[img]/w3timages/icons/tongue.gif[/img]
ohh.. i thought there was something wrong w/ that picture.. considering i use to own an SUV and knew this car really wasn't close to having the same feeling of being higher up like i use to feel..
that's for clarifying.. but it is amazing it's only a little shorter than the explorer in length.. this is a long car.
I've noticed how tall the G is when viewed near other cars. Gives it tons of headroom and probably helps the aerodynamics, too. Backseat is spacious and was one of the deciding factors for me (doors also swing wide for easy access). I'm not sure how the government classifies cars but I assume it's black and white. The G must be right at the cutoff point for compacts.
HTBomb's Magical Hot Wheels
It is cut & dried. Cars are classified by interior passenger & luggage (trunk) volume. A Compact has between 100 and 109 cubic feet, a Mid-Size has between 110 and 119 cubic feet.
Car: passenger volume + trunk volume = total (classification)
Acura 3.2TL: 96 + 14 = 110 (Mid-Size)
BMW 3-series sedan: 91 + 11 = 102 (Compact)
BMW 5-series sedan: 93 + 11 = 104 (Compact)
Note that these above are EPA's numbers, not manufacturer's numbers. I can't find EPA numbers for the G35, but Infiniti's numbers show it here:
G35 Sedan: 98.0 + 14.8 = 112.8, placing it as a Mid-Size, though the EPA classifies it as a Compact. EPA v. MFR numbers seem to vary by as much as 2-3 cubic feet, so they might be rating the G35 at 109, but I can't tell.
At any rate, it's cheaper than a 3 and bigger than a 5.
Definately longer than the wife's Grand Cherokee (but lacking in cargo volume).
Although, my 6'2" coworker bumps his head on the roof and has to lean the seat back when I drive to lunch. I do have the sunroof scraping a couple of inches off.
Definately longer than the wife's Grand Cherokee (but lacking in cargo volume).Although, my 6'2" coworker bumps his head on the roof and has to lean the seat back when I drive to lunch. I do have the sunroof scraping a couple of inches off.
G35s is
1. long in length, wheel base is longer than most of mid-size.
2. narrow in width, about same as bmw 5, but narrower than most of mid-size.
3. tall in height, both on body and trunck which gains the interior cubic inch numbers.
4. clearence is higher than my old max, marginally smaller interior than my old max.
next time my friends tell me "Your G35 looks small", I'll tell them 'yeah, the window sticker says it's a compact, but SURSEY SAYS It's a MID-SIZE'
G35s is
Guest
Posts: n/a
Check the comparison feature at Edmunds, versus a BMW 5-series. You'll find the G35 has more interior room, plus a bigger trunk than a 530i or a 540i. Definitely a mid-size!
VQ power rules.........G35 luxury leather, sport suspension, desert platinum, willow leather
