My dilemma after dropping my g35x with z springs.
Old Jul 10, 2006 | 10:01 AM
mikeee2's Avatar
Hello all,
I've been having this dilemma after dropping my g35x with unrevised z springs. I've posted similar threads on the "sticky about x's" but I figured maybe the general public can help me on this. I'll try to make it brief as possible. After the dropped, my rear has severe negative camber (-2.5 and -2.9). The ride is a little stiff and the oem shocks doesn't seem like it can handle the z springs. I also might be getting rub on the fender after the drop (small cuts on the top side wall of the tire). So here's my dilemma:
1) Slap the stock springs back in, shell out a few more hundred bucks, call it a day and go back to stock. Seems like the consensus is, I shouldn't do this because the drop just looks so damn good.
2) I am fine with the front drop but the rear drop is bit low for me especially when I load people in the back. I can try coupe springs in the back but I am getting conflicting issue about the height of coupe springs vs z springs. I was under the impression that coupe springs can bring the car another half inch higher so I can get the camber back to a closer spec. Yet, I've also read that the coupe springs are the same heights as the z springs.
3) Fix the rear camber with a kit and then roll the fenders afterward. I don't have a clue how the camber kits work. If you guys can shed some light, I would greatly appreciate. Where does the camber kit mount? Will the camber kit need to be removed if I need suspension work in the future (like changing shocks/springs). What camber kit works for the X? I've read Kinetics are affordable. How much does it cost to install rear camber kit?
Sorry to have such a long post. If you guys want to see pictures or more details, let me know and I'll post them.
As always...thanks for any response.
Old Jul 10, 2006 | 10:35 AM
DaveB's Avatar
The rear camber is adjustable to a degree, unlike the front. I'd say spend the $50-70 and get some Coupe springs and install them in the rear just to see what happens. The X's suspension is a bit different than my RWD's so maybe there is the possibility that the Coupe springs may raise the rear of your X.
Old Jul 10, 2006 | 10:48 AM
Neal376's Avatar
the rear geometry of the X is the same as the RWD. no worries there.
dropping your vehicle on springs is never a perminent solution.
someone mentioned tein helping him out with a full blown kit.
I would say just bare with the ride untill that kit comes out.
you will be fine, no worries
Old Jul 10, 2006 | 10:56 AM
mikeee2's Avatar
The kit is for shocks/springs right? Not a camber kit?
Neal, don't you need to fix your camber issue too? I believed you have toe issue also.
Old Jul 10, 2006 | 10:58 AM
yeahdickey's Avatar
Get a realignment ... they can def. do better than that.
I have pretty much the same set up as you and my camber is still off, but acceptable in my opinion and much better than that. and I had to go back for a 2nd alignment to get the numbers I have (see here)
Old Jul 10, 2006 | 11:17 AM
godmans's Avatar
well, IMO, you should go with some coupe/Z shocks (revised) that can handle the punishment of the Z springs that are shorter and have more spring force.
OR
If you wanna do it right (and have the right budget), you can go for sth like Tokico D-spec, which has many postive comments from users on this board
Old Jul 10, 2006 | 11:19 AM
mikeee2's Avatar
Hmm...thanks. I'll see if anyone is selling coupe springs. The thing is everytime I try something, I need to shell out labor $. It's adding up.
Old Jul 10, 2006 | 11:29 AM
Neal376's Avatar
toe sh-moe!
my car is fine!
I dont care, ill just wait until a kit comes out. my tires seem to be running fine
Old Jul 10, 2006 | 11:50 AM
mikeee2's Avatar
How much did you pay for your lifetime alignment at firestone? Maybe I should get a lifetime alignment so I can have it adjust a few times. Right now I am paying $60 per alignment.
Since you have the same tire size as mines, are you getting any tire rub? My offset is higher than yours but I think I am getting small little cuts on the top of the tire sidewall (which might be from rubbing)
Old Jul 10, 2006 | 12:25 PM
mikeee2's Avatar
Let's see if you guys can take a stab at this for me.
I just noticed 3 of the 4 avon tires have very small horizontal cuts on the top of the sidewalls. I understand if the rears are being cut by the inner fender but I don't see how that can happen to one of the front tires. Has anyone noticed their tires with little cuts after being lowered?
Below is a shot of the cut being circled in green. The rest of that "line across" are from the tire gel that I applied a couple days ago. If I use fingernail and push the "cut area" up or down, it's clearly a cut inside. Not deep but it's not a scratch for sure.
Is this what happens when the tire rubs against the fender. I've never lowered any of my previous cars before so I don't know what the symptons are when the tire rubs against the fender.
Old Jul 10, 2006 | 12:40 PM
jimmyc13's Avatar
I don't know much about rubbing & what the cuts would look like, but let me ask you two questions which may put your mind at ease:
1) Do you know for a fact that these weren't there when you got your tires?
2) (more importantly) - are the cuts in random places like you circled, all the way around the tire, or just in select spots? The reason I ask this is if your tire were rubbing, how could it "cut" in only these small locations only? I would think that if you tire were to "rub", then it would be a much longer area that is affected (since your tire is spinning at a very high RPM while driving, the area that will have contact will be very large) and also, I don't think you'd get a literal "cut" in the tire, yet you would have more like an abrasion from rubbing.
Anyone agree/disagree with me?
Old Jul 10, 2006 | 01:29 PM
mikeee2's Avatar
1) That I am not sure. I never pay attention to the sidwall before. Sorry...
2) There are small cuts. But they are all about the same size and. It's random around the tire. Maybe 5 or 6 spots. The reason I asked is because I never had tire/fender rub so I don't have a clue how it looks.
Old Jul 10, 2006 | 01:43 PM
BigSash's Avatar
Hey bro if you want to fix your rubbing roll your fenders.
I own a professional fender rolling tool that I have rented out to a few forum members for $40 + shipping. You can find them online for rental at about $50-75. I offer the $40 rental to G35 forum members only so if you are interested or want more information then send me a PM, but rolling your fenders is the clean way to fix the rubbing issues once and for all without damaging your car.
Gl
Old Jul 11, 2006 | 12:25 AM
mikeee2's Avatar
DaveB, should I just get the coupe springs or should I consider coupe shocks or z shocks for the rear also? Since I believe the rear is the same for awd and rwd. Will those combo throw the car off???
I got a couple of sellers PMed me for their 04 coupe springs. One of them have 30k miles and the other 40k miles. Is that alot of mileage on the springs?
NailBomb
Oct 28, 2015 07:53 AM
leo38cheng
Sep 29, 2015 05:43 PM
leo38cheng
Sep 25, 2015 01:47 PM
lavtxa
Sep 21, 2015 11:51 AM
vstring
Sep 11, 2015 02:50 PM
