OFFSET Question
Old Aug 2, 2006 | 10:05 AM
fokai's Avatar
OFFSET Question
will this set-up work, 20x8.5 +35 front, 20x9.5 +40 rear
Old Aug 2, 2006 | 10:56 AM
ttrank's Avatar
Grocery getter
Yes.
Depending on your tire size you may rub and need to roll your fenders but probably not.
Please search next time. This has been discussed sooooo many times.
Old Aug 2, 2006 | 11:50 AM
sliderg35's Avatar
The front is OK but the rear will rub unless you roll.
Old Aug 2, 2006 | 11:57 AM
heyitzalex's Avatar
rear u will rub, get some tires with a round sidewall, but i would go somewhere between 43-48 to be safe.
Old Aug 2, 2006 | 12:00 PM
LuXXXz's Avatar
dude it aint gonna rub if u dont have a drop
im gettin a 20x10 in the rear w/ a +40 offset and its not going to rub unless you drop
and i spoke to a guy that has those size rims on his G35 sedan and he said he rolled his fenders when he dropped it otherwise it was good
Old Aug 2, 2006 | 12:06 PM
az1anbeethoven's Avatar
^^+1
Old Aug 2, 2006 | 01:01 PM
vodkarocket's Avatar
Modded Member
See what happens when you bolt them up. You WILL rub!
Old Aug 2, 2006 | 02:04 PM
ttrank's Avatar
Grocery getter
If it is stock height you will be ok.
I have 10" rear wheels (+43) with a 275/30/20 and a 1.0" H&R rear drop. I had to roll mine. If these are 0.5" narrower with an offset almost the same you might be ok with a mild drop like the older 350Z springs.
Key word... might
Old Aug 2, 2006 | 03:30 PM
LuXXXz's Avatar
i talked to the guy on cardomain that had the wheels im getting and he had the same exact offsets on his 03 and he said there was no rubbing at all, even w/ people in the back, until he dropped the car Im not positive on what kind of drop it was, but he said he then rolled the fenders
Old Aug 2, 2006 | 04:22 PM
Modded Member
That's great, your experience may vary.
Old Aug 2, 2006 | 04:38 PM
Klubbheads's Avatar
I agree with u. it is not going to be constant rubbing but it will rub if u have people in the back and ur making a right or left turn or going over a small bump. That is the most annoying crap ever.
Old Aug 2, 2006 | 05:36 PM
LuXXXz's Avatar
that ill have to agree with and i actually didnt ask him all that
but on a straight road (im assuming he was talking about that) he said no problem
Old Aug 2, 2006 | 07:47 PM
ttrank's Avatar
Grocery getter
If you are not sure just cut or roll your rear fenders. It is not hard to do. Just make sure and heat your paint a little so you don't crack the clear coat.
Old Aug 2, 2006 | 07:54 PM
fokai's Avatar
can someone explain the process of rolling the fenders. i'm pretty sure i will have to do that because i will be dropped on eibachs pro. do you have to take it somewhere to get rolled or can you do it yourself? thanks.
Old Aug 2, 2006 | 08:21 PM
codeflux's Avatar
take it to a body shop to get the fenders rolled. you don't want to crack your paint and have to repaint half the car.
+43 or +45 would be good offset for 8.5" wide rim.
