Jack point for G??
Old Feb 13, 2004 | 03:39 AM
skeleton_cru's Avatar
Sedan
Re: Jack point for G??
Rhino Ramp...
Old Feb 13, 2004 | 09:24 AM
PotomacG's Avatar
I have jacked my G35 sedan with my floor jack
by raising via the side sills, no problem. The lift portion
of the jack has some indentations around the circular end.
I just make sure the indents match up with the sill indent.
<hr></blockquote>
Ditto!
If you're carefull, a standard floor jack will work fine with no modifications. Common sense is the only tool needed. I would be carefull about letting a tire shop or Jiffy Lube use a spider jack though. Those guys are careless as hell. It makes life just a little bit more difficult.
Old Feb 13, 2004 | 09:22 PM
Sedan
Sounds like a pretty precarious point to use a floor jack. I would not recommend this at all. Use your scissor jack on the side sills, use your floor jack on your underbody jack points. Period. That's what they were designed for.
Marlin84
Apr 1, 2020 12:52 PM
Jeff T
Sep 30, 2015 02:00 PM
Hogbone
Sep 28, 2015 06:44 PM
