Need Help..Anyone with Unrevised Z springs and Tokiko D-Specs
Old Aug 10, 2006 | 01:04 PM
marksg35's Avatar
I have a 05 6MT sedan.I want to use 350z unrevised springs with Tokiko D-Spec
shocks.Does anyone have this setup?How is the ride compared to stock sport suspension?How is handling?
Thanks,
Mark
Old Aug 10, 2006 | 01:56 PM
ttrank's Avatar
Grocery getter
Should be great. It will be a little more stiff than the sport. You should do that and put on some upgraded sway bars while you are in there. They help a lot!
Old Aug 10, 2006 | 02:08 PM
dklau33's Avatar
I have an '04 Sedan 6MT and have this setup. It's good bang for the buck and has worked nicely for me on the street and light duty tracking. I have it set at 4.5 F 5 R for the streets and it's comfortable enough considering the crappy roads I drive on everyday. For the track I've used 2 all the way around and it's pretty stiff and works quite well for a mild suspension setup. Hands down this will be a good improvement over the stock sport suspension as the valving and adjustability is superior.
Old Aug 10, 2006 | 03:44 PM
az1anbeethoven's Avatar
i have the 05 and i used the 350z revised springs and shocks...rides really good...
Old Aug 10, 2006 | 05:42 PM
jameyb's Avatar
I agree the ride will be better but why not go with revised z springs if you are going to upgrade the shocks/struts?
I went with unrevised but that's just because I didn't want to upgrade shocks.
Old Aug 10, 2006 | 11:17 PM
marksg35's Avatar
Thanks for the replies...I'm looking for a ride thats somewhat similar to stock with a slight drop as I have Coupe 19" and 35 series tires... Also looking for better handling...I do have stillen sways as well...I understand the spring rate on the unrevised springs is the same as the 05 sport springs...I don't want to have to firm of a ride...
Mark
Old Aug 12, 2006 | 07:22 PM
geeitup's Avatar
Unrevised springs will drop the car about 1/4 inch more in the rear. I had eurethane spacers made to event it out - 3/4 inch all the way around now. I had an extra set made it you're interested.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Chauzilla
Sep 27, 2015 04:34 PM
