Tire Width on g35 Sedan
Who is rockin the Widest tires on this Forum whats the highest you can go without rubbing anyone in the 300's ? Pics would be nice
275/30/20's
Have not seen wider. You might be able to fit 285's with just the right offset and rolled fenders but it would be very close! I tried 285's on mine and they were a no-go.
Yea same here i just got 275's in the Rear and im like i got to go Wider. Nothing like seeing a Viper pull up with thoses Sick *** wide tires.. It might just be me but whatever. And is it true that 245s are the bigest you can run in the front j/w. Also Any of you running lower then a 40 Profile in the front.. Last time i bought tires from Tire Rack, they would not sell me anything under 40 Profile in the front said it would mess with the (ABS or something ).
Thanks
Thanks
Thanks
Thanks
Yea in the front im lagit with 245's. Last night i was looking at the Rears and it looks like their is about a good inch or two of room on the inside. Thinking about getting my Rims Widened. I dont no what my offset is im running M45 rims with a 5 mm Spacer.
255/40-18 with 35mm offset, no camber correction on 2" drop (I'll take all the free -camber I can get)
Tire to felder lip clearance
Same thing, but innner suspension upright clearance
265 in the front will also clear. 275 front is debateable, 30mm offset required to clear upright for sure.
