21k Maintenance
Old Aug 23, 2006 | 02:33 PM
GeezerB's Avatar
21k Maintenance
My 04 sedan just turned 21k. Any recommendations on required maintenance I need to perform? I try to do most of the work myself. I did bring it in to the dealer for a 10k checkup (whatever that is). I just installed new tires so rotation is not needed. Cabin air filter was recently changed. Oil has been changed every 3500 on the mark. New K&N is clean. Did I overlook anything? The dealer desperately wants me to bring it in for a rip off service. Trying to avoid that.
Thanks, GB
Old Aug 23, 2006 | 02:39 PM
cato's Avatar
SouthernComfort Moderator
Just do what the owners manual recommends. Screw the Stealership!
Old Aug 23, 2006 | 02:59 PM
g35rcr's Avatar
you can check the radiator fluid, brake pads, clean the throttle body, clean the maf sensor, check belts
Old Aug 23, 2006 | 04:31 PM
ttrank's Avatar
Grocery getter
Yeah look in the manual for maitenance intervals. Might want to do your tranny fluid and rear dif fluid. I change those about every 10k.
Old Aug 23, 2006 | 05:14 PM
AgentAero04's Avatar
check your radiator cap,I'm told thats where the thermostat is.Maybe replace your engine coolant if you haven't already.
Old Aug 23, 2006 | 05:21 PM
Jeff92se's Avatar
Red Card Crew
Marlin84
Apr 1, 2020 12:52 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
c_elliott83
Sep 25, 2015 07:55 AM
DRG35R
Sep 16, 2015 05:33 AM
