Walbro install in Sedan. Perfect 52psi!!!
Old Aug 24, 2006 | 11:42 PM
QuadCam's Avatar
WOW! Finally, it looks like the G sedan has some thing good. I swapped in a Walbro GSS342 (thanks Sharif!!!) tonight. I was already aware that there were some differences on the sedan pump setup (thanks Phunk!). All the little places that usually get modded on the G and Z pump housings aren't there on the Sedan.....what the sedan does have seems to be a substantially better flowing regulator!!!
I had to make the usual trimmings of the pump tabs (and a couple others) to fit the pump in to the housing. When I reassembled it and started the car, the car had a perfect 52 psi fuel pressure at idle! I have onlt let it idle for a few minutes, but I am so excited that I don't have the 80psi problem that the coupes and Zs get when installing a walbro!!!
Old Aug 24, 2006 | 11:53 PM
ttrank's Avatar
Grocery getter
I put a Walbro 255 in my car and have not had any problems either.
Old Oct 8, 2006 | 08:10 AM
Dan_K's Avatar
So, if you had 80psi, how much would your mpg go down by? Can the 80psi problem be corrected by adding just a AAM Fuel Pressure Regulator?
Old Oct 8, 2006 | 09:23 AM
bugsdad's Avatar
what does the Walbro do to improve the fuel flow?
Old Oct 8, 2006 | 11:52 AM
QuadCam's Avatar
it provides more fuel, but if your engine doesn't need it( or can't use it).....it is not a worthy mod.
essentially, it is only needed if going turbo, SC, or N2O
Old Oct 9, 2006 | 10:36 PM
Dan_K's Avatar
Why wouldn't the sedan have the 80 psi problem as the coupe? It's the same fuel system.
Old Oct 9, 2006 | 10:47 PM
QuadCam's Avatar
it isn't the same fuel system!
the pump housing, regulator, etc are totally different.
You can geta look at the coupe/350Z pump housing on the turbonetics online instructions. Go take the sedan pump out of your tank and you'll be looking at something different!
Old Oct 10, 2006 | 12:00 AM
ttrank's Avatar
Grocery getter
They are different, but not totally different.
Old Oct 10, 2006 | 08:26 AM
QuadCam's Avatar
it looks the same until you start taiking it apart and then you realize that not much is the same. the biggest difference is the return flow off the regulator. I believe that is why we sedans guys don't have the really high fuel psi at idle when installing a bigger pump.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Tony_Me22
Jul 17, 2015 06:30 PM
