Highest mileage G35 on here? (Do not post less than 500,000 miles)
Old Oct 19, 2019 | 02:35 PM
  #601
Eric@TCGMiami's Avatar
Holy **** man, that can't be on the stock engine right?
2nd motor..
First one snapped the crank in half. Had a bad motor mount, it lifted hit the hood landed and snapped in half internally
Old Oct 22, 2019 | 08:51 PM
  #602
389,173
Old Oct 22, 2019 | 09:10 PM
  #603
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
@Eric@TCGMiami So this thread has a lot of potential for data, long-term what kind of issues have you had beyond all the normal 200k mile issues.
We know that EVERY bushing will need replaced, motor, u-joints, driveaxles, etc. What are some of the odd things that have failed and at roughly what mileage did they actually fail.
Specifically any of the REALLY odd things, like glove box hinges, trunk manual release, door hinges, etc. Any info you can share will be invaluable for the future as everyone catches up to you.
Old Oct 22, 2019 | 09:20 PM
  #604
Urbanengineer's Avatar
I'm excited for 400k!
Old Oct 22, 2019 | 09:36 PM
  #605
The Dog Bones
I hate those bastards!!
I want to say every 50k i change them.
Now im getting stupid quirks, foot pedal sensor went out the other day.
But How about this when I have an opportunity later Tomorrow I will give a full analysis's of just about everything for the most part I have changed out everything and replaced it with the either a higher performance part or I have custom made something to enhance it.
Old Oct 23, 2019 | 04:03 PM
  #606
Texasscout's Avatar
My 2005 sedan has half that mileage
Hood latch broke off 100K
left rear mount for sway bar broke 130K
dash is all cracked 100K
passenger seat has rip, don't remember when.
sun roof leaks still
started using oil at 100K
Old Oct 28, 2019 | 02:32 PM
  #607
React's Avatar
Originally Posted by Eric@TCGMiami
The Dog Bones
Patiently waiting
Old Dec 25, 2019 | 02:08 PM
  #608
390,236 Miles
Swapped out the Rohana's for the GTR stocks.
GoodYear Eagle Sports
Front 245-35-20
Rear 255-35-20
Ran 275-30-20 in the rear but did not like the ride quality. So to stay within the aspect ratio I lowered the width a bit. The tubs are wide so they slightly stretch the tires.
Front wheels needed a 5mm spacer to clear the spindle arm. With about 1mm of clearence.
The car to this date consumes oil, i guess its because the 2005's had this issue. Back at 179k i swapped out the 03 vq35 for the 05, as I exploded the crank... still havent opened that motor to figure out how it happened.
Does not burn oil, or drip... just dissapears 🙄.
Car performs very well.
Low 14s high 13's @ 96 to 99mph depending on conditions / launch etc..
Quirks:
Seat electronics starting to give out
steering rack appears to have a bad tie rod.. has a slight thump at low speed turns.
time to change headlamps
Heat isnt working great... has to be at 90° to give heat, but if you try to blend it to say 80 it comes out cold. No air in the system, just weird!
Old Jan 3, 2020 | 03:51 AM
  #609
390,343
So, took the car to The Alignment Factory here in South Florida...
Camber Bushings Shot off 🙈..
Called Kinetix ordered a new set.
Direly looking for a rear wrecked g37... looking to make a mega transplant, and twin turbo or single turbo the old lady.
Meanwhile, i'll keep posting mileage and issues.
Old Jan 6, 2020 | 02:07 AM
  #610
Dope eric. Crazy how things wear!
Old Jan 6, 2020 | 02:12 AM
  #611
Wish this would allow to reduce image sizes..
Tried to post the photo, the bushings looked like cookie monster ate through them.
Considered going with the spherical but holding off as I am contemplating obtaining a G37 and swapping everything needed out to make it work.
Might need some input from TTRANK as well 🤠
Old Jan 6, 2020 | 02:14 AM
  #612
Haven't seen his posts in a bit, but @TTRANK !
Old Jan 23, 2020 | 08:29 AM
  #613
The old lady
Old Jan 23, 2020 | 08:58 AM
  #614
Construction site!!!?
Old Jan 23, 2020 | 09:01 AM
  #615
i knew i'd catch heat..
Im the Safety Manager for Rizzani De Eccher.
We are building the Miami Signature Bridge.
This pic is the pre cast segment yard. We will be making segments and they will be installed through the course of the night.
