Fast Intentions Sedan Exhaust Coming!!!!
Old Jan 23, 2007 | 11:43 PM
  #196
5150DS's Avatar
I appreciate your not putting a half ****d system out there just to make money. I was wondering if you considered a single system just to see if gains can be made. I'm sure if you made a good single system with the attributes you are looking for (especially a good sound and little or no drone) alot on here would be interested. I am not an expert, but isn't the true dual mostly good for FI. Most sedan owners (I'm assuming) are N/A and wouldn't care if you made a true dual or a single. Maybe try a poll to see what others want. I myself would be happy with a single system with a good sound.
Old Jan 24, 2007 | 05:04 AM
  #197
Neal376's Avatar
what do you guys think causes all the drone?
Old Jan 26, 2007 | 07:34 PM
  #198
jaspergtr's Avatar
untuned resonance.
Old Jan 26, 2007 | 08:39 PM
  #199
DP03's Avatar
I never had an aftermarket exhaust on the G. Is what FI saying true? That every single aftermarket system out there up to now has drone? I find that odd because with my SRT8 I tried a system that sounded great but had bad drone(JBA) in same rpm range, (1800-2200) and then swapped it out for a system that also sounded great with no drone (Corsa). That car hasn't been out as long as the G and has much more exhaust noise to tame, but someone quickly came up with it. Surely someone can make one for the G ?
Old Jan 26, 2007 | 08:42 PM
  #200
GGRJR's Avatar
It my understanding is that nearly all of the G systems, have drone at different RPMs or are extremely loud, or both. The trick is to get a good, reasonable, sound, no drone. Now all of this has to be done, while still getting appreciable power increases.
Old Jan 26, 2007 | 09:06 PM
  #201
DP03's Avatar
I would check Corsa out. I'm not sure they make V6 apps, but they are very popular with the performance V8 crowds and tuners. Skip Barber has chosen that exhuast as their exhaust mod of choice on the SRT products, and lots of Vette tuners use Corsa as well. Funny thing is, it's one of the only straight through exhausts out there for the SRT, and one of only two that has effectively eliminate drone. There is NO perforations in the mufflers and NO filling, and there are no baffles (Flowmaster style). It's actually straight pipe through the mufflers with a few slits in the front of that interior pipe. I really don't know how they did it......
Didn't see the G on their website, but may be worth giving them a call
www.corsaperf.com
Old Jan 27, 2007 | 11:25 AM
  #202
ttrank's Avatar
Grocery getter
I had a little drone with my Borla but not enough to ever bother me. I added high flow cats and it got bad.
The best trick is test pipes and a pair of turbos. Now it's a little deeper and has no drone. It's the best sounding V6 exhaust I have ever heard.
Old Jan 27, 2007 | 11:26 AM
  #203
machavez702's Avatar
That's sounds like a good solution to me. TT to eliminate the drone....hmmm. I thought I was suppose to turn up the stereo to drown it out?
Old Jan 27, 2007 | 11:39 AM
  #204
GGRJR's Avatar
At 400 horsepower any exhaust is going to sound excellent from the drivers seat.
Old Jan 28, 2007 | 11:11 AM
  #205
ttrank's Avatar
Grocery getter
But it sounds good at any rpm and any gear.
The low rpm (1500-2500) 3rd gear drone is gone.
Old Jan 28, 2007 | 04:15 PM
  #206
ISMSOLUTIONS's Avatar
www.corsaperf.com
Chambered mufflers are based on reflection and should give good results, at a performance cost however...though slight. Also, you can't compare how a V8 and our VQ's are together for the same result. Just because a muffler combo can quell a V8 - doesn't at all mean it will work on a V6.
For instance - take the magnaflow Camero muffler - one of the first and only direct swap mufflers for the coupes. It gave nothing but drone and deep deep sound. It took Magnaflow 3 years to bring out their exhaust for the cars, and they re-engineered that muffler to add reflection principles to it for effectiveness. I understand it sounds pretty good, but drones a bit for he coupes after about 750 miles or so when it is mostly seasoned.
The engines in the engines in the sedan put our much more low end pulse than the coupes. The cams are different, and I'm not sure about other issues. Also, the car is longer and it has much more metal in the cab, which is a paradise for drone. The stock resonator, that flat ugly behemuth, is really effective at drowing the drone...but the performance degration of the smaller pipe and the bends they put it through to get it quiet, is what we all have to do without, and try to re-produce in a 'pretty and effective' way.
Rick
Old Jan 28, 2007 | 08:10 PM
  #207
bert039's Avatar
You lost me here. I haven't seen this reported by anyone ever. How are the cams different between the coupes and sedans? Lift, duration, whats different??
Old Jan 28, 2007 | 08:17 PM
  #208
tkman00's Avatar
yeah i didn't think the cams were different. i thought it was different ecu tuning
Old Jan 28, 2007 | 08:19 PM
  #209
Neal376's Avatar
def different ecu...gas cap on sedan says "premium recomended" and on coupe premium is required
Old Jan 29, 2007 | 12:10 AM
  #210
IP05G35's Avatar
The cams can't be different since the output is the same on the VQ35DE in coupe and sedan versions.
