Nismo 350Z Springs
Old 09-05-2006, 12:26 PM
jimmykce1's Avatar
Nismo 350Z Springs
I found a person selling nismo 350 springs off his 2003 350Z. I would like to know if they would fir on my 2006 G35 Sedan. I am looking at lowering my car a little more than stock. Please let me know if this would work and also if I am going to need adjustable camber kits.
Old 09-05-2006, 01:24 PM
Gsedan35's Avatar
All of the suspension stuff that guy is selling on ebay are NOT Nismo parts, they are oem 2003 parts. I messaged him on ebay to let him know. He's selling the parts for his son in law, so he doesn't know any better. He even has rear shocks listed as fronts, rear spings listed as fronts ect. If he doesn't fix his ad's within 24 hours of me messaging him I'm going to report him as fraud to ebay.
If they were Nismo springs, you would HAVE to buy aftermarket shocks, I would recommend D-specs. Flat out no way you can run springs that stiff on oem shocks. Also, oem sedan shocks are too tall for that kind of a drop, which would be about 1.6".
Old 09-05-2006, 01:29 PM
ttrank's Avatar
Grocery getter
If you want a little bit of a drop then the 350Z springs are what you should get.
Old 09-05-2006, 01:31 PM
az1anbeethoven's Avatar
jimmy..i already pm'ed you in detailed on what you should use for your setup, camber, etc...
Old 09-05-2006, 02:01 PM
Gsedan35's Avatar
Just to say it, avoid oem 2003 and 2004 oem 350Z shocks at all costs. Not unless your getting the front shocks for free and your getting upper shock mounts with dust shields/bump stops attached. Remove the shocks and safely dispose of them. Revised 2004.5+ shocks are a totally different matter.
az1anbeethoven, do you happen to have pics of the shocks from your oem 06 Z setup that clearly show the front and rear shock part numbers? If you do, was the donor Z a coupe or a roadsteer?
Old 09-05-2006, 02:14 PM
sorry dont have the pics or part #s...
Old 09-05-2006, 07:28 PM
jimmykce1's Avatar
I will look for 2005+ 350Z revised springs than.
Old 09-05-2006, 07:38 PM
absolutg's Avatar
workin...
no you should be looking for the UNREVISED springs. i have the exact same car as you... unrevised matches the spring rates of your shocks....
Old 09-05-2006, 07:58 PM
unrevised (03-04) springs if you're using existing shocks...revised (04.5 and up) if you are getting springs shocks combo
Old 09-05-2006, 08:04 PM
absolutg's Avatar
workin...
yeah it sounds like he's looking for springs only
Old 09-06-2006, 06:27 AM
jimmykce1's Avatar
I was but it seems people on here said I need to get adjustable shocks too, which I am looking at getting the D-Specs. Now I need to find someone selling 2005+ 350Z springs.
What is the drop with 350Z springs??
Old 09-06-2006, 11:52 AM
it's 1" all around...it's perfect for me...there's a sticky in the tech forum all about the 350z suspension...go check it out
Old 09-06-2006, 11:57 AM
absolutg's Avatar
workin...
you don't need adjustable shocks if the springs you get match OEM, ie: the unrevised Z springs...
Old 09-06-2006, 01:02 PM
basus's Avatar
Which company makes the unrevised Z springs. I am also thinking of dropping the car by 1" all around and will the unrevised Z springs fit my 2005 G 35 sedan 6 MT
Where can you buy and whats the total cost involved
Is is just fine that you replace the springs only or you need to do perform something else too
Old 09-06-2006, 05:50 PM
absolutg's Avatar
workin...
u need to get them from a Z owner... only '03 and '04... '04.5 and later has revised springs
Quick Reply: Nismo 350Z Springs
