License Plate Problem
Old Sep 10, 2006 | 10:50 AM
robbie51981's Avatar
I just got my renewal tags in the mail and I went to take my plastic cover off the license plate in the back and one of the screws will not come out...it just spins. I can get one out and I looked at what held it in and it looks like there is a nut on the other side of it. It seems to just be spinning. I have tried everything to get that stinking thing off but nothing is working. Does anyone have any suggestions??? If not I may be forced to take the whole rear bumber off to get to it and I dont want to do that. How hard is it to remove the rear bumber anyway???
Old Sep 10, 2006 | 12:30 PM
NonAme's Avatar
ez.
u need two tools. screw driver and dont know the name for the other one. It's like a flat head driver but with the center cut out. so its like two teeth on the end but in the middle theres space to fit the screw in between. Lets call it X tool. So u need Xtool and screwdriver
Take the xtool and fit the screw inbetween it and pull it towards you so that its tight on the inside. while doing that use ur screwdriver and start unscrewing the thing. the xtool is use to stop the spinning by tighting the space of the nut on the inside and leaving you to unscrew the screw spinfree.
understand my jumbo humbo? im handicap when it comes to describing things.
well goodluck
Old Sep 10, 2006 | 12:49 PM
ill have to try that...i think ive got something similar to xtool so ill give it a try.
Old Sep 10, 2006 | 07:31 PM
35bills's Avatar
Is there a picture of this "X-Tool"?
I'm having the same problem. I was rear ended a couple of weeks ago. My frame to my licence plate was broken( lucky!!!) so I wanted to replace it.
Finally I ended up ripping it off( the frame). Both nuts were seized. I cannot figure out a way to get my hand up behind the rear bumper to grab the nut.
A special tool is neccesarry just for this simple task. What BS!!!
Any luck robbie51981?
Old Sep 10, 2006 | 10:00 PM
no luck...couldnt get it. im afraid its going to come down to be taking this stinking bumper off and I dont want to do that.
Old Sep 11, 2006 | 06:26 AM
35bills's Avatar
Maybe try the stealership or a local garage????
Old Sep 11, 2006 | 09:12 AM
PDT's Avatar
PDT
I had the same problem and tried everything to get it off. Went to Oakville Infiniti and they removed it and put some new ones in. They were suppose to charge me $10 for it, but I got it for free.
Old Jun 4, 2012 | 01:28 PM
RPL's Avatar
RPL
I am wondering if anyone has found a solution to this. I just got a new-to-me G and I cannot remove one screw from the license plate frame to replace the license plate. It spins but "clicks" with each rotation and does not pull out. I believe the threading is stripped on either the clip or the screw itself.
If anyone could help come up with a solution it would be greatly appreciated. It's blood-boiling that I cannot drive my new car because I can't get a screw out of the bumper!
Old Jun 4, 2012 | 01:37 PM
albundy1987's Avatar
I think this is the style of tool they are talking about. It's actually great for plastic rivets. The idea is to pull the head of the screw towards you while you are unscrewing it. Another great tool is very common. It's called your fingernail. Try using your finger nail to pull the head of the screw towards you. I have seen that work a couple of times.
Old Jun 4, 2012 | 02:08 PM
RPL's Avatar
RPL
Thanks.
And nice finger nail comment -- but I keep mine short. Also, I had the same idea in mind when initially trying to remove the screw but I couldn't even get a flat-head between the screw and the plate I'm replacing.
Old Jun 4, 2012 | 04:01 PM
falcor's Avatar
Simplest way is to drill them out.. When I get home I'll post replacement part numbers that I got from NAPA
Old Nov 19, 2012 | 08:11 PM
Marioh's Avatar
Just a quick thank you on this!
I had both the bolts rusted and broke the retainers for them. I started researching how t pull the bumper off and ran across this thread.
Swung by Infiniti and they had me in and out in 20 min at no charge. I don't think I've ever felt that good about a dealership before.
Old Nov 20, 2012 | 07:27 AM
infinitig35's Avatar
Funny, I also had this same problem several weeks ago. However I use a chain nose plier to get the screw out. See attach picture.
File Type: pdf
cmesidewayz
Sep 29, 2015 09:28 PM
boostelevator
Sep 29, 2015 03:23 PM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
