235/50/18 on stock 18" rims?
Old Sep 15, 2006 | 02:39 PM
pHaT's Avatar
235/50/18 fit ok on the stock sedan 18" rims? Car is on stock suspension as well. Thanks
Old Sep 15, 2006 | 03:12 PM
DieselX's Avatar
Yes they would. Lower profile would look better though (the 50 in those specs)
Old Sep 15, 2006 | 03:18 PM
soaped's Avatar
I think the stock size is 235/45/18. going to 235/50/18 will make a big difference in diameter (1010tires.com shows 3.42%).
Is there a reason why you want to upsize from 45 to 50?
Old Sep 15, 2006 | 03:22 PM
codeflux's Avatar
no, the "50" is the % of tire in the side wall. so, this would be HIGHER profile tire, not LOWER.
and if compare OEM 245/40-18 to the proposed 235/50-18, the proposed tire is 6% larger than OEM, which is WAY over the maximum recommended diameter difference of 3%.
in other words, 235/50-18 WILL NOT FIT.
Old Sep 15, 2006 | 03:40 PM
Chico's Avatar
don't do it. not only will it look kinda FAT (no pun intended), but it will throw your speedo off for sure. use 235/45/18 and will fit perfectly.
Old Sep 15, 2006 | 05:21 PM
codeflux's Avatar
sorry, forgot - OEM 18s do come with 235/45-18's.
comparing those with 235/50-18's, the 50s are 3.4% larger. still not a very comfortable situation. stick with 235/45-18. 255/40-18s looks like would fit, but i'm not sure if they would fit on a 7.5"-wide rim.
Old Sep 15, 2006 | 05:47 PM
pHaT's Avatar
Thanks I will stay away from the 50. The stock rim is 7.5"? Would a 245/45/18 fit ok?
Old Sep 15, 2006 | 07:09 PM
soaped's Avatar
255's are too wide for an 18",/ 7.5" wide rim with anything under a 55 profile.
245/45/18 will fit just fine, you will get a beefier look. I don't think you'll be able to go any wider.
Old Sep 15, 2006 | 07:10 PM
TunerDad's Avatar
GOT MODS?
Go with 235/45 or 235/40. I went 235/45 Kumho SPT's and they are awesome. Best tire I've had. Killer grip!!!!! Trust me, I do test them
Old Sep 15, 2006 | 07:50 PM
DieselX's Avatar
I never said 50 is lower profile, I said he SHOULD get lower profile, which is the number 50 I'm referring to. I'd go with 35 heh
Old Sep 15, 2006 | 09:02 PM
Chico's Avatar
it will mount ok on the wheel, but it will bulge a little. personally, I don't like that look, but if it doesn't bother you...got for it. if your tire shop is cool, they can do a test fit of that tire on your wheel and if you don't like it, you can choose another one.
Old Sep 16, 2006 | 01:18 PM
gtbigup01's Avatar
I'm in the same boat. I have a 04 sedan 17" and am upgrading to 18" but I like the 17" F1- GS D-3 tires that came on my stock 17" and am trying to get the same tires in 18" however that tire only comes in 235/50 and 245/45, the rims I'm getting are 18 X 8 so I guess I will go with the 245/45
Old Sep 16, 2006 | 10:21 PM
scc's Avatar
scc
What about 245-40 on the stock 18" rims? That way you get a little more width, and lower profile than the stock set-up. Will it fit?
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Jussumman
Dec 22, 2015 10:23 AM
StephonW
Aug 5, 2015 12:05 PM
