Noise from window when up from molding contact
Old Sep 15, 2006 | 05:11 PM
BJBBJB's Avatar
I have an 06 35X and have had this issue for a while. When the windows are ALL the way up, I hear a tick? noise? (not sure how to describe it) when hitting bumps from the passenger window. This is not one of the "in-the-door" noises I have seen mentioned in other posts. This is definitely coming from the top of the window, where it hits the molding. Take the window down past the molding and it stops. The drivers side will do it once in a while. I know I isolated where it was coming from right becuase I can push the molding from the inside and make the noise happen.
Having been at this a while, I tried the old-fashioned silicone spray routine but that does not seem to work because the molding is pretty hard actually. Almost plastic-ish.
Anyway, any other suggestions? It is really pretty annyoing when the rest of the interior is mostly quiet.
Thanks,
BJBBJB
Old Sep 15, 2006 | 05:19 PM
excluesiveonez's Avatar
sned it off to the stealer... they fixed my creaking issue with no problems at all anymore
Old Sep 15, 2006 | 05:35 PM
obender66's Avatar
There's TSB for that. infinitihelp.com if I am not mistaken.
I didn't do it, but spraying of silicone lube inside the window frame helped-not sure for how long.
TSB call for application of felt tape inside the rubber molding, which goes along the window frame.
Old Sep 15, 2006 | 07:52 PM
BJBBJB's Avatar
Thanks for the thoughts. Silicone did not help for me so I'll hunt for the TSB.
BJBBJB
Old Sep 15, 2006 | 07:55 PM
Neal376's Avatar
its a TSB
window regulator bolt needs to be replaced
it affects the rear two windows
Old Sep 15, 2006 | 09:03 PM
exactamundo neal, thats what they did for my car on tuesday
Old Sep 15, 2006 | 09:14 PM
ABQ_G35's Avatar
I had a noise like this coming from my passenger side, seemed to stop with the window down slightly, but, it turned out to be the armrest, if I touched the armrest it stopped, I guess, the window being up and tight changed something in the position of the door panel.
magnetism80
Feb 1, 2019 10:00 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Detailed Image
Sep 8, 2015 02:42 PM
3000vr4tt
Sep 7, 2015 12:48 AM
Detailed Image
Sep 4, 2015 08:35 AM
