18X9 48ET with 275/35 possible on the rear ?
Old Sep 25, 2006 | 12:15 AM
wiz2's Avatar
Rim gurus unite !
Okay, I have been looking at staggered set ups since I got the car. I've talked with several shops and have various opinions. After searching I see most with a similar set up are runnning 265/35. I would like to run 18x8 38ET w/ 245/40 up front and 18x9 48ET w/275/35 on the rear. Front should be good(many people have it), the rears are my concern(havent seen any on a sedan). I have two shops that say no problem and two that say rubbing will occur w/ 275/35 and I should go with 265/35 or 255/40, I would prefer the larger for tire availabilty and rim protection.
I may or may not drop so I'm on the more conservative side of the spectrum for now.
A buddy has 235/40/18 and 275/35/18 rubber w/ some aftermarket wheels on his M3 Coupe and I think it lookg great. The tire set up looks perfect.
Any thoughts ??????
Old Sep 25, 2006 | 12:27 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Those are some pretty conservative offsets you're going with there. The front will be fine, but i'd definitely go with a more agressive offsets, say +33-35F, +40-45R
-GP-
Old Sep 25, 2006 | 07:43 AM
tkman00's Avatar
tires should be fine. but just to be sure, check the manufacturer specs
Old Sep 25, 2006 | 05:07 PM
ttrank's Avatar
Grocery getter
You will be fine. I have 20x10's +43 with 275/30's on my rear and a 1" drop. I did have to roll the fenders.
Old Sep 25, 2006 | 07:32 PM
soaped's Avatar
one thing you do need to make sure is, check to see if the wheel style clears your brakes!
Old Sep 26, 2006 | 05:59 AM
skeleton_cru's Avatar
Sedan
You won't have any rubbing issues with that set-up. Whatever shops said you will rub (I'm assuming the fenders) with those offsets don't know what they're talking about.
Old Sep 26, 2006 | 02:50 PM
wiz2's Avatar
Thanks for the replies.
I have another question about another set of wheels with the same tire set up 245/40,275/35. These rims are 18x8 40ET front,18x9 40ET rear.
On a side note I was changing brake pads on the wifes 04 Accord. I weighed the 16in factory alloys. They were only 38.5 lbs. Not super light, but lighter than i expected.
Old Sep 26, 2006 | 03:45 PM
soaped's Avatar
18x9 40ET will need some kind of drop and a little neg. camber, might need to roll your rear fenders.
18x8 40ET is fine.
Old Sep 27, 2006 | 12:26 AM
Sedan
18x8 40ET is fine.
Agreed
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
