compression rod squeak
Old Sep 27, 2006 | 11:07 AM
louisdarke's Avatar
i see some of you have claimed lubing the compression rod bushing helps with the squeak a lot of us hear in our sedans. can someone tell me how to properly lube this item? what type of lubre product is best?
i haven't been able to get my dealer (lokey infiniti) to acknowledge the issue yet, so i am willing to try the lube option for now.
thanks
Old Sep 27, 2006 | 11:27 AM
chobble19's Avatar
the stealership has lubed and lubed mine and wont relace the compression rods...they are blaming it on my springs even that it sqeaked before i had them installed!!!
Old Sep 27, 2006 | 11:29 AM
louisdarke's Avatar
yeah, i figured the lube option was not a real fix, but......
i am going to hit the dealer again at my next oil change and see what they say. after that, if they refuse, i may call infiniti consumer affairs and complain.......for what it is worth.
Old Sep 27, 2006 | 03:55 PM
QuadCam's Avatar
what is a compression rod?
are you talking about the suspension squeak?
Old Sep 27, 2006 | 05:16 PM
SFG356MT's Avatar
Originally Posted by S.E.
if you are still in warranty, there is a TSB for it. I got it done one month before the warranty ran out on my 2003.5 I went in Harper Infiniti of Knoxville with a list a mile long of TSBs i wanted checked, and they did every one without even testing to see if they were needed. killed about 80% of the squeaks and groans with foam, they did.
Thanks, good to know.
Old Sep 27, 2006 | 10:54 PM
DrJones's Avatar
Had both front compression rods replaced by SW Houston Infiniti. Unfortunately the noise is back and everytime I complain the dealership responds with, "Cannot duplicate at this time"
Old Sep 27, 2006 | 11:52 PM
mr_ecktid's Avatar
they wanted $800 to replace all of them
Old Sep 28, 2006 | 11:01 AM
chobble19's Avatar
this is the delaers most famous way of saying we aint doooin shiiiii
Old Sep 28, 2006 | 11:49 AM
Jeff92se's Avatar
Red Card Crew
Mine is creaking again now that's cold in the mornings. Problem is once you drive the car to the dealer, everything warms up and the noise wont' happen.
Old Sep 28, 2006 | 11:53 AM
DaveB's Avatar
Mine creak and I've never had them replaced. They only creak under the situations you describe and seeing that Infiniti can't fix the problem, I'm not going to persue the issue. I'll just shoot some silicon at the movement points everyonce in a while. My 03 creaks maybe once or twice a month and it's been that way since I bought the car nearly 2 years ago.
Old Sep 28, 2006 | 01:08 PM
mr_ecktid's Avatar
How much did you pay to have them replaced Dave? Or was it under warranty?
Old Sep 28, 2006 | 02:02 PM
QuadCam's Avatar
where is this part that you guys are talking about? pics?
Old Sep 28, 2006 | 02:58 PM
Clean G 4D's Avatar
fwiw... I thought I had to have the dealer look into this problem too. But I remember someone saying that you get squeaking from your sways if they arent lubed enough. So, I cleaned and re-lubed my sway bar bushings and my squeaks went away. -I have hotchkis sways.
Old Oct 5, 2006 | 08:53 AM
Noremac's Avatar
Can you please provide a reference for this TSB?
