Stillen License Plate Bracket
Old Nov 15, 2006 | 11:12 AM
psedog's Avatar
Back in SD**
Originally Posted by psedog
I've got an 06 AT sedan and after measuring it with a tape measure it appears to be 22mm. I'll double check that in the morning with a Micrometer once I get to work.
Looks like my eyes were wrong, it is 24mm (.95" on the mic). I'm glad I work at a Calibration Lab Woot Woot
Old Nov 16, 2006 | 07:15 AM
Bobalude's Avatar
Originally Posted by StarChamp
There aren't any other options that I'm aware of, and I searched hard. I know somebody on the forum was making custom ones, but I don't know if it ever got off the ground. Good Luck.
maybe ask Clokwork (member on this forum) for insight on whether this works on a sedan:
http://www.nationalgclub.com/gplate/GPlate2.htm
Old Nov 16, 2006 | 10:00 AM
Calvin's Avatar
Overglorified Altima
i have a stillen tow hook measuring guide...but i dont know how to upload it for you guys...
basically you print this sheet of paper out, and cut out the three holes (each hole is a different size - 16, 22, 24) and stick your tow hook in to see which one fits
Old Nov 16, 2006 | 10:02 AM
Calvin's Avatar
found them
http://stillen.com/product_files/Lic...d_Template.pdf
http://stillen.com/product_files/STI...e_Brackets.pdf
Old Nov 17, 2006 | 12:34 AM
hai109's Avatar
It's not the size...It's the threads on the tow hook for the 2006 is different for some reason...
Old Nov 17, 2006 | 01:29 AM
psedog's Avatar
Back in SD**
Originally Posted by hai109
Nah...Did that already...It's the thread that didn't work...I went to the dealer and bought it back twice...I have the guy compare it to the 24mm dia. and it didn't fit the thread...i guess they still didn't make it...
I went to the dealer today and picked mine up for 71 plus tax.
Old Nov 17, 2006 | 02:04 AM
hai109's Avatar
But your car is not a 06...The 06 model has a different thread...
Old Nov 17, 2006 | 02:17 AM
psedog's Avatar
Back in SD**
I hope your joking, if you aren't then here is my proof that I have an 06 (which I posted earlier in the thread that I have an 06)
Invoice
Own Manual
Old Nov 17, 2006 | 10:30 PM
hai109's Avatar
OH...Mah bad...it's a sedan correct...Hmm...I'll go see if it fits then...The reason why i thought it was a 05 was because the 06 coupe has projectors...Sorry bout that...I need to go try again i guess for mine...
Old Nov 18, 2006 | 01:26 AM
psedog's Avatar
Back in SD**
Ask them to try part # 105470
Yes it's a sedan. I was going to say you could try to see if mine would fit yours, but you are an hour and a half away, so that won't work. If you are going to the meet in SD, I could show up and let you test it on your car. If you are then I'll probably show up, though I'm not planning on it, cause I have my 2 year old with me and I don't think it would be right to bring him along. If you are send me a message.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
dcsbh1
Oct 1, 2015 03:15 PM
