2006 Sedan not prewired for Sirius???
Old Oct 16, 2006 | 11:36 AM
SavageHenry's Avatar
I had my Sirius all ready to install this past weekend and when I went to install it, I could not find the prewired bracket in the trunk. I bought the Sirius unit and antenna from Grubbs.
Am I missing something?? Are the directions different for a 2006?
I'm thinking about just taking it to best buy unless anyone has any ideas.
Thanks in advance
Old Oct 16, 2006 | 05:20 PM
BuckeyeG's Avatar
I think its under the dash on the pass. side
Old Oct 16, 2006 | 07:03 PM
5150DS's Avatar
It is in the trunk under the carpet behind the rear seat towards the passenger side.
Old Oct 16, 2006 | 07:26 PM
Hmm, under the dash or rear seat?
Anyone else try this on an 06?
I guess I can try both places this weekend.
I removed the spare tire and carpet and looked behind the drivers side seat but now that I think about it I didn't look behind the passenger side.
Thanks guys, anyone else run into this?
Old Oct 16, 2006 | 08:56 PM
TunerDad's Avatar
GOT MODS?
Great question. Anyone know where it is on the 2003 sedan?
Thanks
tD
Old Oct 17, 2006 | 10:54 AM
sliderg35's Avatar
It depends on your VIN number. Somewhere during 03.5, they started pre-wiring. Before that, they did not put the wire there so you have to buy the wiring harness as well. I think Grubbs lists the VIN numbers that are pre-wired. You can just check yourself also. In the trunk, on the passenger side behind the rear seat. You should be able to find the wire close to the bottom of the trunk (if it's there).
Old Oct 17, 2006 | 11:01 AM
kki000's Avatar
I have an 06, the harness is above the trunk, near the speakers, on the other side of the package shelf, right side as your looking into the trunk. You need to remove the liner at the top of the trunk, that part was a pita.
Old Oct 18, 2006 | 10:23 PM
Thanks I'm going to give it another shot this weekend and see if I can find it.
Old Oct 20, 2006 | 10:24 PM
06 Stock 6MT's Avatar
Location of prewire sat radio
The sat. radio pre wire in the'06 sedan is located in the trunk on the passenger side. You will need to undo all the plastic rivets on the top portion of the inside of the trunk; you also need to take out the trunk lining on the right rear (passenger) side. You will see the Bose Amp, FM radio tuner, speakers all on under this trunk lining. I would visit the site below to download the instruction manual.
http://www.grubbsperformance.com/Mer...=G35SedanAudio
Old Dec 14, 2006 | 12:42 AM
redliine's Avatar
I just bought my gf the Sirius Satellite kit for her 2006 sedan (receiver/display, antenna etc). Hers does not have Navi. I didnt even know her 06 was pre-wired for Sat radio.
Is it hard to install? Or should I take it to the dealership or a good audio place?
Whoa after looking at the intructions i'll just take it in to get it done haha..
Old Dec 20, 2006 | 01:49 AM
redliine's Avatar
Soo..
If your car is pre-wired for Satellite radio, when you press the RADIO button on the stereo, it should roll thru FM1, FM2 and then there should be SAT ?
Is that correct?
Old Dec 20, 2006 | 08:09 AM
ORANGEBSRT's Avatar
Yup
Old Dec 20, 2006 | 09:57 AM
chobble19's Avatar
damn that does look kinda complicated to install =/ i got the sirius unit coming for xmas!
Old Dec 20, 2006 | 12:53 PM
emlevins's Avatar
OK - if the car is not prewired for Sat (no SAT option when pressing Radio button sequence), I assume this part (AAI-NIS2) listed here: http://www.pac-audio.com/products/pr...iliary%20Input would not work.
Is there another means to do a direct connect of an aftermarket SAT radio to the OEM HU or are we forced to use an FM tansmitter?
Old Dec 20, 2006 | 07:30 PM
BuckeyeG's Avatar
I dont think it will go to sat on head unit unless it rads the actual unit hooked up.
nickmcc123
Lights
Oct 7, 2017 12:18 AM
derres
Aug 28, 2015 03:27 PM
TreeFiddy
Aug 10, 2015 06:50 PM
wuppiedog
Aug 7, 2015 11:16 AM
