tire pressure sensor
Old Oct 18, 2006 | 11:33 PM
Andy77's Avatar
Originally Posted by Msedanman
What's on the sidewall is Maximum safe inflation pressure, not what is recommended for service.
Your sedan should be around 30. I ran mine about 33-35 tops.
You'll need new sensors for the new wheels which will then have to be initialized by the dealer.
C.
I agree about the pressure. It seems to be a common mistake to inflate tot he maximum tolerated pressure that the side wall gives, even though street cars are never designed to use those pressures.
I thought the sensors were in the inflation valves and you only have to have these transferred from the old to the new wheels (carefully) to have the system work with the new wheels. Please correct me if I am wrong.
Old Oct 19, 2006 | 12:32 PM
ttrank's Avatar
Grocery getter
That's true. I took the sensors out of my oem wheels and put them in the new ones.
Old Oct 19, 2006 | 01:17 PM
ITmenace's Avatar
Strange thing..I live in So Cal and my TPS has been coming on the last couple of days also. I have aftermarket wheels but never had problems before. It must be because of the low temp(58 degrees) we have been having in the morning.
Old Oct 19, 2006 | 01:31 PM
ttrank's Avatar
Grocery getter
Temps can change the pressure in your tires quite a bit. Back when I was keeping 35lbs in mine the sensors would come on from time to time but once they got warm they went off. I try to check my pressure every month or so.
Old Oct 19, 2006 | 01:49 PM
ITmenace's Avatar
Yup because by afternoon it would clear itself.
Old Oct 19, 2006 | 02:00 PM
GEE35FX's Avatar
Andy, this is what they look like, apparently they will not fit in some custom wheels.
Old Oct 19, 2006 | 04:27 PM
ttrank's Avatar
Grocery getter
That's them. They fit most aftermarket wheels.
Old Oct 19, 2006 | 05:25 PM
jimmyc13's Avatar
Just an FYI...they say that a ten (10) degree drop in temperature results in approximately 1.0 psi pressure drop in a tire (and visa versa). Seems to be true, as the weather is getting colder in the northeast, my psi has been 1-2 psi lower, so I added some air.
Old Oct 19, 2006 | 07:44 PM
kevink's Avatar
I know that I used to use the pressure on the tire as the desired pressure, instead of maximum. Changed when I got new tires on a previous car that had a max of 44, rather than the 35 I was used to.
I was under the impression from something I read that car companies tended to understate the pressure to give the car a softer ride.
Old Oct 20, 2006 | 08:18 AM
Quickie's Avatar
Used to run 37-38 psi in my 03 max. But due to the horrible roads in Memphis, I broke both of strut mounts twice in 8 months and my alignment was always screwed up. Maybe giving it hell all of the time had a little something to do with it as well. Now I run 33-34 in the G. It rides better and I feel more calm about pot holes and my struts. No problems after 15k miles.
Old Oct 23, 2006 | 08:44 AM
Andy77's Avatar
Gee35X-thanks for the picture. I'm not planning on seeing mine soon!
jsimonk
Dec 22, 2023 03:49 PM
Muski_G
Dec 1, 2023 11:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
stay_tuned
Jul 21, 2015 07:09 PM
