Does brake fluids get consume as the brake pads wear down?
on
Originally Posted by Nismo G
depends on how you use the rotors. If you daily drive then probably every 50-60K miles. If your into tracking and what not well thats a different story.
Originally Posted by DaveB
Jeff's right. Also, make damn sure you loosen the brake reservoir cap while doing brake work because when you compress the pistons, the fluid will rise. If you topped off the fluid, it will leak out. If you don't collect the fluid before it leaks out, it will eat the paint.
Personally I loosen up the brake bleeder ports on the calipers when changing pads so that the older fluid gets pumped out when pushing the pistons back into the housing. Then I do a proper bleeding.
on
Originally Posted by Grumpy_G
^^ GaryV01, sounds like your rotors are glazed. Repeated heavy use will cause the rotor to become surface harden and coeffient of friction goes down.
Just have your rotors turn, and if the pad is still good, leave it on. Useless you're switching up the compound!
Originally Posted by Garyv01
I C...u know what the weird thing is...my front pads seem to be fine but my rears are pretty low...isn't it supposed to be the opposite way around usuallY? so u are just saying i need to get my rotors resurfaced?
johnadlertech
Accessories
09-01-2015 08:15 PM
