sway bars???
Old Oct 20, 2006 | 11:37 PM
luky1380's Avatar
Angry sway bars???
hi folks
i have G35X 5AT
got my sway bars tooday
was trying to install them rear feats perfect
but with front i endedup in deep ****
it looks defferent and when i instaled it and put the car down it was having no grownd clearans sway bar ended up beeng about 2.5'' from the grownd
so i even couldnt drive out from diveway cause it heet the road
and a Q: is : is font sway bar for G35 coup deferent fron G35 sedan???
cause i think they may just send me wrong set
thanks fo any help
Old Oct 20, 2006 | 11:46 PM
sliderg35's Avatar
It should look exactly like the old sway bar, just bigger around. So, there should be no diffrence in ground clearance.
Old Oct 21, 2006 | 03:36 AM
skylineguv's Avatar
Front shocks on a G35X are different to the rwd sedan/coupe and I'd assume that the front sway bar is different from the rwd aswell.
Old Oct 21, 2006 | 03:39 PM
luky1380's Avatar
so i gues ill call those ppl on monday and talk to them about it
Old Oct 21, 2006 | 05:21 PM
ttrank's Avatar
Grocery getter
Yeah the X is different.
Old Oct 21, 2006 | 05:37 PM
G-Mony's Avatar
Originally Posted by luky1380
hi folks
i have G35X 5AT
thanks fo any help
I tried this too w/ Cusco sways and had to return the front. Not only is X front different from coupe but also RWD sedan due to AWD differential is located low near front bar. only thing you can do w/ the front sway is have it custom frabricated thicker.
Old Oct 21, 2006 | 07:07 PM
chobble19's Avatar
what kind of sway bars did u get?
Old Oct 22, 2006 | 11:34 AM
sliderg35's Avatar
X or no X, the new sway bar should look like the one you are taking off with just a difference in diameter and multiple mount points on the end. Do you have pics of old and new?
Old Oct 22, 2006 | 07:23 PM
VQ Hotness's Avatar
Do they make a Strut bar for the sedan ?
Old Oct 23, 2006 | 02:06 PM
luky1380's Avatar
i got one from vendor in her
it hotchkis swaybar
Old Oct 23, 2006 | 02:09 PM
luky1380's Avatar
one company das it i soow them somewere it was abou $450
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
