SCRAPING NOISE when turning - 2004 G35 SEDAN
Old Oct 29, 2006 | 09:36 PM
kidymonite's Avatar
I hear a weird scraping noise whenever I make a left turn or go in reverse. Sounds a little like metal scraping on the pavement. I checked the tires, and under the car, and everything seems fine. Anyone have any idea what this could be?
Old Oct 30, 2006 | 08:28 AM
bert039's Avatar
Have you checked your brake pads?
Old Oct 30, 2006 | 08:58 AM
kidymonite's Avatar
no, but car only has 8500 miles. should brake pads have issues with such little mileage?
Old Oct 30, 2006 | 11:00 AM
bert039's Avatar
Under normal circumstances, no. Normally you should get a lot more life out of new pads.
But you never know, it could be an abnormal problem. Its worth it to check it out real quick. From what you described it sounds like the pads are worn out and the low pad indicator is starting to scrape, making that noise.
Old Oct 30, 2006 | 11:17 AM
ttrank's Avatar
Grocery getter
Also check your fender liners. Something may have come loose and is rubbing on the tires.
Old Oct 30, 2006 | 08:47 PM
ITmenace's Avatar
Wow!!! you have 04 with only 8500 miles? Just take it in and have it checked out because it doesn't sound like a common problem.
Old Oct 30, 2006 | 11:04 PM
NaztyG's Avatar
ure brake shield on the back of ure breaks is prob bent and hitting the rotor when load is put on that side.. very common prob have that checked
Old Oct 30, 2006 | 11:43 PM
AthensBlueG's Avatar
Brian
Hey dude, I had the EXACT same problem you described just a couple of months ago. The car made a horrible metal grinding noise when I'd turn left sharply. A bent metal rotor cover on the backside of one of your rotors sounds like it could be the culprit. But in my case, it turned out to be a pebble from my morning commute that got wedged somewhere and was scraping the rotor shield when I turned the wheel. The dealer found a tiny rock the size of a pea and took it out for me - no charge, either!
Take it in to a dealer to get it looked at, immediately. You're under warranty. If it's simple to fix, they may just help you out and do it for free.
Old Oct 31, 2006 | 12:03 AM
ttrank's Avatar
Grocery getter
I didn't even think of this. I would bet that's what it is.
Old Oct 31, 2006 | 10:19 AM
kidymonite's Avatar
Thanks fpr the info. Bringing it in to the dealer tomorrow.
Old May 29, 2021 | 04:27 PM
Varkonio's Avatar
Infiniti g35x
What did it end up being? I have the same problem.
Old May 29, 2021 | 08:58 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
No one has responded to this thread since 2006, I strongly doubt you're going to get a reply.
Put the car on jackstands, take apart the brakes on the corner that's making noise, it's probably a rock trapped up against the dust shield on the back of the rotor or something like that. It's happened to me on a few vehicles.
Old May 29, 2021 | 09:09 PM
Varkonio's Avatar
Infiniti g35x
Yeah I figured that was it because it just started today after driving down some really rocky roads. I’ll try this out and if it there’s nothing there then my next idea is the wheel bearing or driveshaft. It’s a 2006 g35x.
vmcarbuyer
Oct 12, 2019 12:42 PM
brycealbr
Aug 11, 2015 11:47 AM
igking
Jul 19, 2015 01:12 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
