Alignment!!!
Old Nov 13, 2006 | 08:40 AM
ORANGEBSRT's Avatar
Alignment!!!
When I put 19's with the H&R drop, am I goin g to need a camber kit or would I be able to align it. The drop is only 1.3 in front and 1.2 in rear.
ANY SUGGESTIONS????
Old Nov 13, 2006 | 12:44 PM
ttrank's Avatar
Grocery getter
I can answer this one since I have those springs with 20's.
You can align the caster and toe within spec. The camber will be a little out of spec but not too bad. The G has a decent amount of negative camber stock.
But if you want to get away from wearing out the inside of your tires you will need a F&R camber kit.
SPC makes a great kit. But remember to weigh the price. It's just not worth it for the front kit IMO. You can get the rear arms and toe bolts for cheap but the front kits are at least $400-500. I drive ~15k a year and those miles are hard so I like some negative camber. I just swap the tires side/side once or twice over their lifetime.
Old Nov 13, 2006 | 02:47 PM
ORANGEBSRT's Avatar
Would I Be Able To Get Less Negative Camber Since I'm Going With 19's Instead Of 20's ?
Old Nov 13, 2006 | 02:49 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
No, the camber is affected by the suspension changes.
-GP-
Old Nov 13, 2006 | 02:55 PM
ORANGEBSRT's Avatar
I know that suspension affects camber......but what i was saying is......is there more room to play with the camber to get it almost perfect?
Old Nov 13, 2006 | 02:57 PM
no, 19's and 20's wont make a difference in the play with the camber toe. I'd suggest getting the SPC rear camber kit as Ttrank did previously. I'm dropped 1.7/1.3 on tein basics and i'll be getting the SPC kit shortly. It is not very expensive and is very easy to install.
-GP-
Old Nov 13, 2006 | 04:14 PM
soaped's Avatar
I have about 1.4"/1.0" drop in front/rear after the h-techs settled and my front camber was -1.4 and rear was -1.1. The caster and toe were all right on oem.
The rear camber is adjustable to spec, but the fronts are not.
with -1.4/-1.1 you will still wear unevenly. It usually shows at about 20k in a 300AAA rated tire if you aren't a burnout happy monger.
like ttrank said, rotate your wheels correctly and it will minimize uneven wear.
I am going to get a front camber kit eventually, but right now I don't drive enough to warrant it =D
Old Nov 13, 2006 | 04:17 PM
ttrank's Avatar
Grocery getter
What they said.
Old Nov 13, 2006 | 04:36 PM
ORANGEBSRT's Avatar
appreciate all the info. Thanx
Old Nov 14, 2006 | 05:47 AM
jimmykce1's Avatar
-GP-
I am getting ready to buy the SPC front camber kit too. My fronts are out about -1.2 camber. Since I never installed a camber kit on my car, I would like to know if you have to remove the springs to install them. Looking at the pictures I would have to say No. Please let me know if I am correct.
Old Nov 14, 2006 | 02:11 PM
no, you do not have to remove the front strut/spring assembly to install the front camber A-arms.
-GP-
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
