2006 350z rims on 03-04 Sedan?
Did anyone do this? I was thinking about putting them on my 04 desert platinum. Post some pics if you can....
Also how much is a full aero kit these days?
Originally Posted by Jeff92se
Should fit. They are about the same size as the G coupe 18s 18x8 and 18.8.5 with 30 and 33mm offsets.
Those offsets are pretty aggressive for the sedan, even in those wheel sizes. I think it would be ok but you may want to do the math first.
From memory, they are about the same as the other Coupe 18s. Yes if lower than .5" or so, the wide 245 rear might cause some rubbage.
I have a set of those wheels for my stocks but I never used them, the reason I have them because I upgraded my brakes with the brembo's from a 350z and these set would clear w/o any problems. But now I posted them on ebay because I'm starting on my sound system over the winter for next years car shows. Its under l_e_o_designs on ebay!
Why do I bother to DIY???
They should fit, but the rear will mostly likely rub. Those are the same widths and offsets as the Coupe 19s as well.
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
