Help! /w alignment
Old Nov 26, 2006 | 09:37 PM
kimro's Avatar
Help! /w alignment
My car is pulling to the right and I have no idea what else to do.
- Got alignment done. Nothing was off to pull the car to right.
- Checked tire balancing twice.
- Tried rotating tires to every possible combinations.
Any suggestions on what to do? I don't even know what to ask for anymore..
Thank you.
Old Nov 26, 2006 | 09:39 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
hmmm... cant be a radial pull since you rotated the tires to all the different positions. Sounds like your caster is out. Only way that could happen on this car is if you were to hit something pretty hard. The caster isnt adjustable without a camber/caster kit.
-GP-
Old Nov 26, 2006 | 10:48 PM
ttrank's Avatar
Grocery getter
Does it pull all the time? Might be road conditions. If a tire rotation and alignment does not help I don't know what to say.
Old Nov 27, 2006 | 09:04 AM
kimro's Avatar
Definitely not the road conditions as it pulls right even on road where the car should pull to the left (decliene to the left)
Old Nov 27, 2006 | 09:28 AM
35bills's Avatar
Have you lowered your sedan?
Do you have a spec sheet for the Alignment results? If so, could you post them up?
Old Nov 27, 2006 | 10:40 AM
ORANGEBSRT's Avatar
Do You Have Directional Tires? If U Do, It Will Always Have A Pull Because Of Road Conditions. If Its Non-directional, U Have Another Problem.
Old Nov 27, 2006 | 10:42 AM
Nismo G's Avatar
First of all what year is your car? If its an 03 or 04 im pretty sure that their was a TSB on a part that was causing all the Gs to drift to the right while driving, even with perfect alignment. If this is the case i would take it to the dealer and just get the part changed out...
Old Nov 27, 2006 | 12:48 PM
ttrank's Avatar
Grocery getter
Good point.
Worst case have the dealer do an alingment and if it still pulls they can help figure out the problem.
Old Nov 27, 2006 | 01:40 PM
kimro's Avatar
I will have the alignment results posted as soon as I get it scanned.
My car is stock 03 sedan with 0 mods.
Tires I currently have on my sedan are Hankook w409i, which looks directional to me.
Nismo_G >>
I'll check with my local dealer regarding the possible recall. But I don't see it on http://www.infinitihelp.com/Infiniti...s/G35/2003.htm list. Do you know the recall number?
Thanks guys! I'll give my local dealer a call. If there's more suggestions, do feel free to list them for me.
Old Nov 27, 2006 | 01:50 PM
Nismo G's Avatar
Nismo_G >>
I dont remember seeing it anywhere someone had told me about it a while back.
Old Nov 27, 2006 | 01:54 PM
RetAF's Avatar
A TSB is NOT repeat NOT a recall. I have seen TSBs issued to correct a page or paragraph number in a publication. Most TSBs give instructions or alerts to the techs on a problem, but a recall is an entirely different animal!
Old Nov 27, 2006 | 02:03 PM
kimro's Avatar
RetAF, Thanks for the clarification! Love this forum... helps me look less of a dummy when talking to actual mechanics, service reps, etc
Old Nov 27, 2006 | 02:14 PM
35bills's Avatar
If your tires are directional, there would be an arrow located on the sidewall, pointing in the direction of rotation.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
