Help me decide...Rims
Old Nov 27, 2006 | 03:37 AM
lukmee's Avatar
Exclamation Help me decide...Rims
Hi... Please Help me decide!!!!
I plan to get new rims.What the best offset on my G35 sedan Between?
(1).5Zigen Sports Engine: Hyper Dark Front is 19x8.5 +38 & Back is 19x8.5 +45
(2).HP racing EVO Dark Wheels offset all around is +38
I have already gotten "TOYO" -T1R- Tires Front is 225/40/19 & Back is 245/40/19. I want drop my car with Tein H-techs. What you guys think?
Is there any problem about rubbing issues in the future?
Should I move tire pressure from the old wheel to new wheel?What will happen if i do not put tire pressure to the new wheel? Thanks....
Attached Thumbnails Help me decide...Rims-sport_engine_hypblkwssl.jpg   Help me decide...Rims-hp-racing-evo-dark.jpg
Old Nov 27, 2006 | 03:47 AM
cungkpham's Avatar
i like the first one. the 2nd one has too much going on. my opinion
Old Nov 27, 2006 | 03:54 AM
G35Papa's Avatar
#2 but with size and offsets from #1 and 9.5 in the rear instead of 8.5
Old Nov 27, 2006 | 04:17 AM
03DSGCobra's Avatar
Start a poll, I really like #1.
Old Nov 27, 2006 | 09:42 AM
Chico's Avatar
If you're gonna stagger the tires, you should also stagger the wheels. Otherwise run 19x8.5 +38 w/245/40/19 all around or 245/35/19 to keep the sporty look of the car.
If you go staggered, your best option are the 5Zigen wheels. 19x8.5 +38 front with 245/35/19 and 19x9.5 +45 rear with 275/30/19.
Old Nov 27, 2006 | 09:48 AM
Mike@DW's Avatar
My SSR GT10's with rear's of 9.5 and +47 offset on 275/35 were perfect. Did not have to roll the fenders.
Old Nov 27, 2006 | 10:05 AM
fastGkid's Avatar
i'd go with the 5zigen
Old Nov 27, 2006 | 10:39 AM
DVatz's Avatar
Coupe 6MT
#2 looks better, but would be a pain to clean around all the small crevices. Definitely try for a deeper dish in the rear though, that's the way I'd go.
Old Nov 27, 2006 | 11:52 AM
darnelled's Avatar
I was considering the same 2 and chose the HP's for the darker finish that comes on the edges of each spoke. It gives the appearanc of more depth. I went with 18x8 +38 offset with 245-45-18 tires all around. This was an "upsized tire size" and I did the 350z spring drop. The tires come close to rubbing the rear fenders when under heavy loads. I'd at least go with a +40 offset next time.
Old Nov 27, 2006 | 12:19 PM
chinaman_87's Avatar
both are a good choice but id go with the second one.
Old Nov 27, 2006 | 12:42 PM
ttrank's Avatar
Grocery getter
I like the HP's better.
If you plan to get wider tires for the rear then see if the make a 9.5" or 10" for the rear. Otherwise I would do the 245/40's all the way around. You may run into VDC problems with a 225/40 and 245/40 being too far off in diameter.
Old Nov 27, 2006 | 12:46 PM
VQ Hotness's Avatar
They both look the same...
Old Nov 27, 2006 | 12:47 PM
ttrank's Avatar
Grocery getter
Close but not exact.
Old Nov 27, 2006 | 02:13 PM
az1anbeethoven's Avatar
if you have the funds, get the 5 zigen, take a look at the lip, it's high polished...and the hp has a dull lip...
Old Nov 27, 2006 | 02:35 PM
4 Door Skyline's Avatar
I dunno man...but im a fan of JAPANESE wheels for our cars....HP is a local company for me and well....here in miami, they are kinda considered cheapy cheapy wheels.....know what I mean??
