Valentine 1 Help
Old Nov 29, 2006 | 10:20 PM
speedracerg35's Avatar
you may be plugged into the wrong connector. mine shuts off immediately when i shut the car off. also, all bogeys all the time.
Old Nov 30, 2006 | 12:16 AM
Nickk6's Avatar
Any pics of the inviscord?
Old Nov 30, 2006 | 06:34 AM
BuckeyeG's Avatar
I bought the fuse box adapter to pluged it into a open fuse slot in the panel and mine shuts off with the key. Its like a $12 part that can be bought and the parts store.
Old Nov 30, 2006 | 04:04 PM
ttrank's Avatar
Grocery getter
I ran new wire up to mine. Can't help with what's up there now.
Did you get a mike's mount for it?
Old Nov 30, 2006 | 04:09 PM
Jeff92se's Avatar
Red Card Crew
I believe you must have tapped into the constant power vs switched power. Just review invicord's website and look at the install section for the wire color.
Old Nov 30, 2006 | 08:35 PM
MrBig's Avatar
It works on my machine
I have the escort with the invisicord and mine shuts off with the car. But when I had my '05 it didn't shut off I had to unplug the cord all the time. It could have been me and I tapped into the wrong cord or something.
Here is some install instructions.
Yellow goes to the black with pink stripe mirror wire
Black goes to the black mirror wire
Hope that helps.
Old Nov 30, 2006 | 08:42 PM
G SEDAN's Avatar
well if you think about it...constant power is for the homelink, and the one that shuts off with the car is the auto-dimming mirror feature...make sure you tap into the auto-dimming mirror not the homelink, you should be fine.
Old Nov 30, 2006 | 10:58 PM
sly1types's Avatar
if u are getting a lot of false alarms you can use semi logic the the small L or full logic the the big L, I usually use small L and it work great!
Will_blueprint
Jun 28, 2004 09:37 AM
2fast
Apr 7, 2004 06:55 PM
coolie
Mar 18, 2004 04:43 PM
lebushaw
Jun 14, 2003 09:38 PM
