Replacing Brake Pads
Old Dec 4, 2006 | 08:37 PM
medgar's Avatar
Does $400 sound about right to replace my pads for an 03 non Brembo set? My rotors are not being replaced.
Old Dec 4, 2006 | 08:58 PM
Jeff92se's Avatar
Red Card Crew
Sounds like highway robbery to me.
Old Dec 4, 2006 | 11:02 PM
saborz's Avatar
Is Suburban Infiniti doing the job for you? OEM pads?
Old Dec 4, 2006 | 11:37 PM
jimk's Avatar
no, sounds too high. also try hawk pads - no dust
Old Dec 5, 2006 | 10:00 AM
medgar's Avatar
I was thinking of taking it to Suburban Infiniti, but I thought let me get some quotes from other places first. Belle Tire told me $400. Don't you think the dealer would be more expensive then them?
Old Dec 5, 2006 | 01:21 PM
cato's Avatar
SouthernComfort Moderator
Sound about right if it includes new rotors. If no rotors, it is robbery!
Old Dec 5, 2006 | 01:26 PM
Jeff92se's Avatar
Red Card Crew
$400 for just pads?? How much do pads cost? Is it even front and rears? Let's say it's $175 for front and rear. So labor is $225? For what? 1 hour of work? Insane.
The question if you need/don't need rotors is how close they are to the min thickness. Or if the rotors have deep grooves or are warped. There is absolutely no way to tell this over the net and you haven't offered any info pointing either way.
I just bought some pads and did my own. At 30k, the fronts were toast but the rotors were okay. Rears were fine.
Old Dec 5, 2006 | 01:34 PM
jimmyc13's Avatar
That price is rape....you're better off getting some aftermarket pads, since you have an '03...it will cure your brake dust issues immediately! I got Hawk HPS front & rear pads for $125 & did the install myself (using DREWER's DIY thread). Never changed brakes before in my life!!!!
Old Dec 5, 2006 | 09:57 PM
saborz's Avatar
Suburban Infiniti quoted me about $290 per axle to replace the pads and turn the rotors. They said to add an additional $140 per rotor if the rotors need to be replaced.
Old Dec 5, 2006 | 10:14 PM
gary c's Avatar
Pad replacement.............
    I just paid $125 for a complete set of Hawk HP pads for my '04 Non-Brembo
    coupe.............$400 seems excessive........don't drop the soap!! Install
    can be accomplished in 30 to 40 minutes and I
    don't have airtools. Order your own pads and find someone to install them
    if you don't have the time..........$400 yea right!!
    Old Dec 5, 2006 | 10:48 PM
    medgar's Avatar
    Thanks for the info! I think I am going to buy my own ceramic pads and have someone help me install them. Especially if I can save $200-$300. I guess I have to call Suburban and cancel my inspection.
    Old Dec 6, 2006 | 01:29 PM
    jimmyc13's Avatar
    If you live in Michigan and drive your car in the winter, you may want to reconsider. I didn't go ceramic, as after doing research on the advantages & disadvantages, ceramics only operate & function to their full potential in warmer climates & when they're heated up (like track use)...not truly sure how well they'd work for you, so you may want to ask around. Just a suggestion before you fork out the dough for them.
    wuppiedog
    Aug 7, 2015 11:16 AM
    kinetek
    Aug 3, 2015 04:25 PM
    sahizzle110
    Jul 29, 2015 11:36 AM
    EnCr1pt3d
    Jul 29, 2015 03:35 AM
    emorehs
    Jul 17, 2015 09:45 AM
