2007 automatic transmission issue
Old Dec 9, 2006 | 06:02 PM
Johnnie Rockett's Avatar
I have just purchased a 2007 G-35 sedan with the automatic (5 speed) transmission. The issue I am having is this - The tranny will kickdown to a lower gear at the smallest press on the gas pedal. Usually the kickdown is anywhere from 1 - 2 inches from the floor on most cars. On this car is about 1 inch from the top. This results in a very annoying ride (being so touchy). The tranny does not seem to be "happy" with small adjustments of the throttle ... almost instantly searching for a "better" gear.
What I am trying to find out is this. Is this an intentional design feature or a flaw? I know that Infinity tried to create a "feeling of unlimited power" in the 2007 transmission shift points, but this seems rediculous. The feeling is "all or nothing when you accelerate. Even when I want to make a small adjustment of 3-5 mph a small press on the gas causes a downshift, a small jerk in acceleration and then an upshift as I back off the gas.
Anybody having the same issue?
Old Dec 11, 2006 | 08:14 AM
bbug's Avatar
Go back and take another G for a drive at the lot to see if yours reacts differently. Keep in mind the new G has a G-force sensor so the transmission will react more aggressively if you happen to be driving aggressively. Lastly, make sure you are not in Sport Mode which is another way to make the transmission be more aggressive and less likely to stay in one gear.
Old Dec 11, 2006 | 09:21 AM
4 Door Skyline's Avatar
it might be the transmission computer getting used to your style of driving, I remember my 05 when I bought it new did something similar, but as the time passed by, it normalized and been great ever since
Old Dec 11, 2006 | 11:25 AM
GeeWillikers's Avatar
Walking The Fine Line...
Use the manual mode, that'll solve your problem!
I don't have an 07, but what you describe doesn't seem right to me. You shouldn't get a kickdown with such a small throttle input. The only time my 05 is sensitive is when I'm in 5th going uphill and I give her a nudge - she drops to fourth very easily, but not so much as to be annoying or inappropriate.
Old Dec 11, 2006 | 11:32 AM
kraqcommando's Avatar
drive faster?
Old Dec 12, 2006 | 04:02 PM
bythabay's Avatar
go back and pick up a 6mt
derres
Aug 28, 2015 03:27 PM
Srinidhi
Aug 7, 2015 03:38 PM
wuppiedog
Aug 7, 2015 11:16 AM
newg37
Jul 26, 2015 09:32 AM
newbdriver01
Jul 15, 2015 06:10 PM
