View Poll Results: how many 6MT owners have had tranny issues?
replaced by dealer
33
15.64%
repaired by dealer
2.37%
need to be repaired or replaced by dealer
10.90%
havnt encountered any problems
158
74.88%
Multiple Choice Poll. Voters: 211. You may not vote on this poll
6MT tranny replacement
Old Sep 20, 2006 | 12:37 PM
chobble19's Avatar
Question 6MT tranny replacement
i wanted to get a brief estimate of how many of us 6MT owners have had their tranny either replaced, repaired, not covered, or not encountered any problems....results should be interesting....i think
Old Sep 20, 2006 | 12:59 PM
basus's Avatar
Have 13K ... no issues till now
Old Sep 20, 2006 | 01:33 PM
Dieselnuts's Avatar
mine was replaced @ 15k
Old Sep 20, 2006 | 01:34 PM
chobble19's Avatar
what for?
Old Sep 20, 2006 | 01:40 PM
Nickk6's Avatar
It rattles I think, could be the engine though.
Old Sep 20, 2006 | 02:55 PM
supra2k's Avatar
i've had mine replaced 3 times, the 5th and 6th gear tend to grind as i enter into those gears
Old Sep 20, 2006 | 03:22 PM
vt_maverick's Avatar
At 45K without any problems.
Old Sep 20, 2006 | 03:28 PM
WaLLy's Avatar
2005 6mt @ 16K miles without any issues..
Old Sep 20, 2006 | 03:29 PM
WaLLy's Avatar
hhmmm, was this pole only meant for the sedans?
Old Sep 20, 2006 | 03:57 PM
CruiseX's Avatar
Not sure if this was for sedans or for coupes, but here it goes. My tranny is all good, but it rattles a tiny bit. I was told by Infiniti that a little bit of rattling is inherent on the 6MT design. However, if you have other rattling there is another source. Some of the cars come off the line with not enough grease on the rear axle for the rear wheel drive. When there is not enough grease you hear the rattle. Apparantly they can tighten things up and re-lube it. This was a big problem on the 03's, and apparantly Infiniti corrected the problem in subsequent years, but there are always going to be exceptions. Mine being one of them. So, before you thing that rattle might be your tranny, ask about the rear axle since it is a definite possiblity. Best be is to have one of the Infiniti mechanics ride shotgun with you and point it out to them when you hear it. If you just hand the car over they are going to say they could not replicate what you were talking about....aka they do not want to take the time and figure it out since it is going to cost them to fix it.
For those of you that had tranny problems....what was the problem and was it fixed under warranty or did you have to dig deep into your pockets to get??? things right
Old Sep 20, 2006 | 04:32 PM
Real_G's Avatar
An Army of One...
2006 Coupe 6MT - 8500 miles
Replaced by the dealer..
Old Sep 20, 2006 | 04:53 PM
norcal_chan96's Avatar
My throw out bearing makes noise... But i think it's normal for the stock clutch... My friends G makes the same noise... When i drive hard it really gets noticable...
Old Sep 20, 2006 | 09:20 PM
Disco_Monkey's Avatar
23K miles, no problems.
Rattling comes from the clutch. It's normal.
Old Sep 20, 2006 | 10:13 PM
Nismo7's Avatar
No Problems
2005 sedan 6mt 26k miles no tranny warranty issues.
Knock on Wood!
Rough to engage if trying to go slow at start. I have always driven standard shift so I'm not a newbie.
Clutch has high takeup so difficult to have consistently smooth starts unless I am trying to get on it. It almost seems to be rougher after rain or high humidity days. Other times it is smooth as silk.
Anyone find difficulty in smooth engagement?
Old Sep 20, 2006 | 10:38 PM
Nickk6's Avatar
I do, it is just because it engages so damn high
