Engine Compartment Cleaning
Old Dec 10, 2006 | 09:58 AM
calesa1's Avatar
Can any one advise if cleaning the engine is safe to "do it yourself", or better left to the "pros"?
Old Dec 10, 2006 | 12:19 PM
RRF985's Avatar
I've only wiped down the engine covers and what not on the G. You should be fine to spray it down. Just make sure the engine isn't hot or you could end up with a cracked block. I've sprayed down the engine compartment on my Explorer a couple times without any issues. I can't imagine there would be any issues with doing this on the G.
Old Dec 10, 2006 | 12:33 PM
nghiars's Avatar
if you go with the spray.. make sure theres no leaks anywhere under the hood...
i personally like to use rags and clean em.. once with just water, 2nd witha lil soap, 3rd wth just water and one more time with a dry rag
Old Dec 10, 2006 | 06:39 PM
kevink's Avatar
The thing to worry about is the wiring/computers. Hopefully, they separate from the main engine block.
From what I've heard, the cracked engine block is probably not a big worry. The engine can get plenty of of water on it while driving in the rain, or going through puddles. I don't hear of too many cracked blocks from that.
Old Dec 10, 2006 | 07:09 PM
G35Dreamz's Avatar
I wipe down the painted areas with spray wax and a rag. The plastic and the hoses, i use armor-all and a rag.
Old Dec 10, 2006 | 08:24 PM
GeeWillikers's Avatar
Walking The Fine Line...
Mine has never been dirty enough to require anything more than a little spray and a microfiber.
EnCr1pt3d
Jul 8, 2019 02:48 PM
linedr89
Aug 17, 2015 05:11 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
justgotg35
Jul 19, 2015 12:33 PM
