First Dyno with the G
Originally Posted by clinthammer
is this the same case with a 2006 g35 sedan? its rated at 289hp. ive got a MD plenum spacer and jwt pop charger/z tube..
https://g35driver.com/forums/g35-coupe-v35-2003-07/124211-dyno-d-results-mods.html
The AT's are eating up more like 20%. My sedan baselined at 215/217. Even with all my mods listed in my sig (not the reflash), it only dynoed at 235HP on the same dynojet. I've probably got 240-245 now with the fuel/timing reflash, but you're not going to get much on these from bolt-on mods. I think I've got about 306 crank now which equals the listed '07 output.
The first '07 dynos on the 5AT's should come in around 240-245 SAE adjusted on dynojets.
seagrasser
May 3, 2022 09:43 AM
