Problem with the Center console Lights
Old May 8, 2009 | 07:02 AM
  #31
acemallone's Avatar
Thumbs up
Originally Posted by G SEDAN
my radio/ac controls wont work and my AC is stuck on AUTO, set at my last temperature setting of 73 degrees whetn it still worked. I can stil control my radio through the steering wheel controls.........cannot control chit from the center console!! HELP!
Talked to Infiniti, A/C compressor has shorted out, and froze you settings. The tech said it is a known problem, bring it in and it should be covered. It shorts out your circuit board.
Should be a quick fix
Old May 12, 2009 | 08:08 AM
  #32
acemallone's Avatar
Problem Solved!!! You have to remove your battery cover and the other plastic peice that is behind it. It is flush with the windshield. There is a fuse panel there, check the 10amp fuse second one down on the left side! Mine was blown, changed it, and now I am good to go!!!
Gip
Aug 24, 2015 05:31 PM
Cacoepy
Aug 3, 2015 01:09 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
