She has twins, greddy twins that is...
Old Jun 23, 2010 | 11:19 AM
  #2146
Gusc35's Avatar
you cant consider the hp or drag coefficient separately when talking about reaching 200+. the question is if you have enough hp to over come the force of the air resistance at those speeds. the force is related to the drag coefficient, but the drag coefficient is not the end all be all. the bugatti veyron has a drag coefficent of .36 in speed mode and .41 in handling mode, both of which can hit 200+ easily. It can do so because it has 1001 hp. Like i said above the question is does tim's car have enough power overcome the drag force at 200mph. The drag force on an object can be determined from the following formula:
F=(1/2)*p*(V^2)*C*A
where p=density of air
V=velocity
C=drag coefficent
A=surface area
the power needed to overcome this force is:
P=F*V
where P=power
F=force calculated above
V=velocity
I dont know what the surface area of the g35 sedan is so i cant calculate exactly what the power would be. These variables are in metric
p=1.204 kg*m^-3 (at 20 degrees Celsius)
V=200mph=322 km/h
C=.26
A=?m^2
Hope this helps
Old Jun 23, 2010 | 02:01 PM
  #2147
ttrank's Avatar
Grocery getter
Well based on the sedan's drag and my power maybe it is possible to get up that high. Going off that spreadsheet with the drag and weight changed my car has 200+hp more than needed...
Old Jun 23, 2010 | 10:34 PM
  #2148
Dan in St Louis's Avatar
Originally Posted by Andrei
That is not accurate at all. It doesn't consider wheel size or final drive or gear ratios.
Andrei, the tire size and gear ratios matter only if they conspire to keep the engine from producing the required HP at the desired speed. For example, "long" or economy-minded gearing might mean the peak HP isn't reached before drag takes over as the limit. Cars have been marketed that are actually faster one gear down from the top, because the top gear keeps the RPM quite low.
Conversely, a drag racer might run out of revs before drag is the limiting factor because acceleration is more important in that car than top speed. The top speed is then said to be "rev-limited."
All any mathematical solution can do is find the limit based on certain assumptions, and the assumption in that spreadsheet is the car is geared so that the developed HP is actually useful, and not just lurking at some high RPM the car can't reach in top gear.
The particular spreadsheet I posted attempts to find the HP required to overcome air drag at a given speed. Since the HP vs. RPM curve for everybody's engine is not known, that's about as good as it can do. That limit is implied in the column headings "HP required" for overcoming friction and drag, and the recognition in the formulas that not all the "flywheel" HP finally reaches the wheels. Those formulas make no claim that they also choose the right gearing to accomplish that.
All that said, it nailed the top speed of my MBZ 560SEC within 2mph.
Old Jun 23, 2010 | 11:21 PM
  #2149
Andrei's Avatar
That's why it's not accurate IMO. And to have the stock drag coefficient you would have to replace the front bumper with a stock one. There is a 3.0 final drive Nissan makes that should yield 200++mph with no problem for a G sedan. 3.2 should work too.
Anyway. You are in Arizona next to the salt flats. Go try it.
Old Jun 24, 2010 | 09:09 AM
  #2150
Gusc35's Avatar
+1
you'll never know unless you try
Old Jun 24, 2010 | 05:28 PM
  #2151
ttrank's Avatar
Grocery getter
Still have the stock speed limit for now.
Old Jul 25, 2010 | 11:01 PM
  #2152
InfinitG5's Avatar
I remember reading this thread when I first joined, this was before I even got my G, and how this kind of lit the fire under my *** to hurry up and get one. Great build sir. Good luck in the future too.
Old Jul 26, 2010 | 01:53 AM
  #2153
ttrank's Avatar
Grocery getter
Thank you
Old Jul 31, 2010 | 10:01 AM
  #2154
kevman's Avatar
love this build. I have a c6, and this has almost double my RWHP. I'd LOVE to get a ride in this thing one day.
Old Jul 31, 2010 | 02:29 PM
  #2155
ttrank's Avatar
Grocery getter
You in AZ?
Old Sep 1, 2010 | 04:37 PM
  #2156
nazc0's Avatar
2006 Vortech supercharged Sedan
hey what tape is this?
Old Sep 19, 2010 | 11:58 AM
  #2157
AJaxx80's Avatar
Superb as usual Tim. Good stuff!
Old Sep 19, 2010 | 12:47 PM
  #2158
ttrank's Avatar
Grocery getter
Wow, old pic. LOL
That is header wrap. I was trying to keep the engine bay heat out of the intake.
Here's a more recent shot.
Old Oct 12, 2010 | 02:01 PM
  #2159
grocerylist's Avatar
Amazing car. I can't imagine how much money went into that car since you started on it.
Old Oct 12, 2010 | 03:38 PM
  #2160
ttrank's Avatar
Grocery getter
Me either. I try not to think about it.
